Hello! can do it with this type of cd player?
Nic93
Is located in south denmark aabenraa/rødekro
Posts 50
Nic93 Posted: Sun, May 7 2017 7:36 PM
is it possibel with a beogram cd 3300 to work on a beovision mx 8000 tv?
Peter
Earsdon
Posts 11,991
Peter replied on Sun, May 7 2017 8:49 PM
Yes, but not as you would want it. You can no doubt get a cable so the audio can go through the TV via either a SCART or possibly S-VHS plugs. The CD would not be remote control. The better way to do it would be to connect it to a MCL equipped Beomaster, get a MCL/ML converter and then you will have full AV integration. The problem you no doubt have is that the Beomaster 3300, although using the Beolink 1000 codes, doesn't work properly with MCL . I would get something like a Beosystem 2300 and simply use ML - the 2300 should be very cheap these days.
Peter
Nic93
Posts 50
Nic93 replied on Sun, May 7 2017 8:53 PM
So i cant hook it thou the input port on the back of the beovision and get sound that is?
since its haveing input for cd playback, right? i was given that specific model thou as a present today.
Page 1 of 1 (3 items) | RSS
