Hi all.
I am repairing a beogram 4002 on behalf of a friend. The clear plastic optical "ruler" with the sense lines is broken and is missing the end piece. Also one of the mechanical leaf switches underneath (the inner limit stop switch) is broken.
I would like to buy these bits, if anyone has parts machine with them still in place please.
Thanks!
Colin.
Both parts exist in more than one version.The ruler with different markings.A couple of photos would be helpful.
Yes, of course. Here are pictures of the two items. The photocoupler lamp arrangement is how it arrived on my workbench, and will be changed back to original.
I discovered the spring for the microswitch in the bottom of the unit, but the actuator lever has a kink in it and the spring does not stay in position correctly, despite straightening.
Also, I noticed the cover for the lamp is missing, so I will have to source this part or fabricate something to suit. I suspect a high wattage lamp was fitted and caused the damage to the optical interrupter and lamp housing.
