Hi!What does Primary and Secondary really mean?
I always setup new NL products with the product i will multiroom "with" most primary and then secondary most secondary.The only place i saw a difference is on my NL/ML Converter. The products was automatically mapped to some functions on the IR Mapping. As i like my IR custom it is actually not very useful for me.So is there anything to gain or loose from using the primary/secondary function?
Actually i found a problem with this primary secondary thing:BLC Line In is IR-Mapped to "TV".If a product is automatically IR-Mapped to AUX. The BLC opens the AUX when i press TV. Not its own Line In as Mapped.I had some problems with the sound from the Line In and by accident i discovered that when i press TV on the Remote in the livingroom the app showed me that the BLC joined the M5 in our bathroom on its line-in. There is no source on the line in therefore there was no sound.I fixed it by putting BLC Line in both TV and AUX on the IR Mapping. In that way the "Primary/Secondary" function does not assign anything automatically to those two functions.
