Feeding the Beolab 5
This post has 19 Replies | 1 Follower
Chris Townsend
Qatar
Posts 3,531
Chris Townsend Posted: Mon, May 15 2017 8:46 AM
I have my lab 5s conn
Chris Townsend
Qatar
Posts 3,531
Not sure what's happened to the rest of my message, but I'll fill it in when I get back from the docsErm..
Chris Townsend
Qatar
Posts 3,531
So everyone I've got these amazing speakers that have a variety of video sources, the primary being the brilliant built in bluray player.
But for playing music I'm using Spotify on an iPad mini, and sending it to an Apple TV on the 7-55. It's very convenient but even to my clogged up lugs surely the 5s deserve better.
We will definitely get a Beosound 9000 in the future, but what options are left to me to play a quality of music befitting the speakers. Playing cds through the bluray player is a quick but clumsy option, and the Moment is of no interest to me. The Beosound 5 with its ripper appeals, but it doesn't support Spotify anymore!
What's left?
Kiran
UK
Posts 1,023
Kiran replied on Mon, May 15 2017 1:14 PM
USB DAC with Coaxial OUT.
Coaxial out into BL5 spdif IN.
Hook the DAC up to a PC, Laptop, android or iDevice and listen through Lossless Tidal.
The DAC must be connected to the audio source via USB.
I think this is it? I have never tried it. I'm sure this works?
And then powerlink both BL5 together?
Regards
Kiran
Born in NL; I ride ML
vlohjr1
Posts 553
vlohjr1 replied on Mon, May 15 2017 1:16 PM
Chris Townsend:
What's left? Beovision 7-55 Mk2, Avant RF 28, Beolab 5, Beolit 15, Beoplay A1/A2, Beocom 2, Beotime, H3 ANC/H8/H6/H2, Form 2, Beoplay A3, Beovision 5-42 connected to a DVD1
Have a look at stb the you can now add a cd player stack to the moment a little pricey though at £650
Kiran
UK
Posts 1,023
Kiran replied on Mon, May 15 2017 1:29 PM
https://www.optoma.co.uk/audioproduct/udac3
This thing is wicked.
Regards
Kiran
Kiran
UK
Posts 1,023
Kiran replied on Mon, May 15 2017 1:35 PM
SORRY - It's only for headphones... my bad
This one completely ready for Android or iDevice but a little pricey.
It has a Wolfson DAC!
http://europe.beyerdynamic.com/shop/a-200-p-eu.html
Regards
Kiran
Millemissen
Flensborg, Denmark
Posts 14,680
The easiest (and also cheapest) way would be to hook up a ChromeCast Audio dongle to the BV using a small optical to coax converter.
You'd probably have plenty of unused spdif coax-in's on that BV7.
You can cast from practically any music service app.
Kiran
UK
Posts 1,023
Kiran replied on Mon, May 15 2017 1:39 PM
bit off topic, MM are you an Android or iOS user?
Regards
Kiran
Duels
England
Posts 2,553
Duels replied on Mon, May 15 2017 1:42 PM
Kiran:
Regards
Kiran
He's an android clearly ! Wink
Millemissen
Flensborg, Denmark
Posts 14,680
Kiran:
The uDAC3 has analog R/L output as well - this would be ok.
Could easily be connected to the BV7.
(I used to have one (version 1) on my desk/the MacMini.
But fiddling with a wired conputer just to hear music isn't for everyone.
Kiran
UK
Posts 1,023
Kiran replied on Mon, May 15 2017 1:45 PM
He just said all music services (apps I think) can see the chromecast locally on the network?
Would iDevices see them in the app?
I am trying to control everything via Beolink2 so I'm thinking on that wave length...
Regards
Kiran
Millemissen
Flensborg, Denmark
Posts 14,680
Duels:
Kiran:
Regards
Kiran
NO WAY !!!!!
It is about the only 'droid device I have.
But I am not religious about this - it is a smart device and a clever solution Yes - thumbs up
Duels
England
Posts 2,553
Duels replied on Mon, May 15 2017 1:49 PM
Millemissen:
NO WAY !!!!!
I know. I was messing with Kiran's question which went as follows; MM are you an android.......?
Bit too subtle perhaps. Wink
Kiran
UK
Posts 1,023
Kiran replied on Mon, May 15 2017 1:55 PM
Yes
Millemissen:
Yes this one has coaxial OUT too but I don't know how to connect it to the iDevice directly.
You would need lighting to USB converter. And then a USB power source input for the uDAC3. Maybe a twin USB with input for power and output going into lighting to USB converter? It's a bit complicated but I have seen a similar setup on youtube: HIFI MAN.
Regards
Kiran
CB
> You are Here <
Posts 1,762
CB replied on Mon, May 15 2017 2:26 PM
Chris Townsend:
What's left?
May I suggest you to read this thread ?
Millemissen
Flensborg, Denmark
Posts 14,680
Duels:
Perhaps.......for me ;-)
Chris Townsend
Qatar
Posts 3,531
Just loaded this Adele cd into the 7-55, to see what it'll do with the Beolab 5s! WOW
At volume 55 this thing rocks, and I worry it'll annoy my neighbours. I can sometimes put on Sky or a DVD on at 75-80 and yeah it's loud, but nowhere this powerful.
The different volume levels on Beosystem 3 can be really annoying. In the mean time, I need a Beosound 9000Yes - thumbs up
Sal
California, USA
Posts 1,197
Sal replied on Fri, May 19 2017 3:28 PM
Chris, congrats on your new BL5's... have you had a listen before and after calibration with the same piece of music and can you share your thoughts on how much the BL5's calibration makes a difference? I know everyone's room is different, but I've heard that some people feel that the BL5 overcompensates in some environments, and owners prefer the uncalibrated sound.
Thanks for your thoughts!
Chris Townsend
Qatar
Posts 3,531
Got home....plugged them in.....calibrated....musicBeer
Page 1 of 1 (20 items) | RSS
