BeoMusic app is merging with Bang & Olufsen app
This post has 306 Replies | 10 Followers
Tassos
Athens
Posts 323
Tassos replied on Thu, May 18 2017 8:38 AM
The idea is great. Combining all B&O apps into one (and I mean ALL of them (BeoRemote, BeoMusic, Beolink)) that you can use whilst on the street in the subway on the airplane or your house.
+1
Millemissen
Flensborg, Denmark
Posts 14,680
Hmmm - why would you want to control something (some devices) in your house,
whilst you are on an airplane or in the street....???
Kiran
UK
Posts 1,023
Kiran replied on Thu, May 18 2017 9:41 AM
Millemissen:
I think this person means to use the app to browse and listen to locally stored music on the iPhone with headphones?
I want this too... It's just something different to using Apple's own music app which is great too...
But the app only lets you connect and play from B&O connected devices... not headphones...
Regards
Kiran
Born in NL; I ride ML
Sandyb
Posts 2,186
Sandyb replied on Thu, May 18 2017 9:58 AM
Hmm, i don't get this at all.....when out and about, playing music on headphones is straightforward...and the native streaming apps are all pretty good....does anyone thin B&O can do a better job of that? moreover they'll be restricted anyway by the 3rd party, so why spend time making a compromised experience...?
and much as many would like (myself included) to be able to chose a streaming service to plug into B&O apps, that's not under B&O's control, a well rehearsed debate i feel.......
Kiran
UK
Posts 1,023
Kiran replied on Thu, May 18 2017 10:04 AM
Sandyb:
True... if it's Deezer, you tap on Deezer.
If it's Spotify or Tidal, then you tap straight on that app.
I wouldn't tap on B&O until I'm home...
Regards
Kiran
Millemissen
Flensborg, Denmark
Posts 14,680
Well, that would be a very limited use of the X-app ;-(
Wouldn't it be better just to have a 'B&O-styled' app for that?
That should be easy to make - just a skin on a local music player app.
When you look into the future, it should be possible to make a set of headphones with the functions of an Essence built-in (tech is getting smaller and smaller...).
And you could use these headphoses just like you'd use your stationary NL-gear - alone or as part of a multiroom setup.
Now, that would be something new - com'on B&O ;-)
Kiran
UK
Posts 1,023
Kiran replied on Thu, May 18 2017 10:16 AM
Millemissen:
Yes! You have put it into good words!
And that's how headphones would connect ๐Ÿ‘Œ๐Ÿป๐Ÿ”ฅ๐Ÿ’ฏ
Regards
Kiran
Kiran
UK
Posts 1,023
Kiran replied on Thu, May 18 2017 10:18 AM
It's all about fast fluid GUI and how pretty it looks lol...
Regards
Kiran
AngloApulian
London, UK
Posts 82
Sandyb:
That's not what I'm referring to in my earlier post. When you're at home and you'd like to play for example hi res 24bit music from a streaming service such as Qobuz wirelessly on your B&O sound system requires integration in the B&O app. AirPlay would be pointless as it can only support up to 16bit music which may be fine for services like Tidal HiFi but anything of higher quality such as Tidal MQA or Qobuz Sublime requires built-in support.
I found out recently that Devialet have managed to do this with their Spark app which proves it can be done. Also have a look at how many streaming services Sonos have integrated into their app. It is possible through third party APIs which already exist and are available to App developers. I just hope over time, B&O take advantage of third-party APIs provided by streaming services to give their customers the option to take full advantage of their B&O sound systems to to play hi-res music from streaming services such as Tidal MQA and Qobuz Sublime as well as others services such as Spotify, Apple Music, etc.
Irvine
Posts 61
Irvine replied on Thu, May 18 2017 10:55 AM
So will this app now support Essence Mark I?  Not clear; please let us know and, if so, when.  Thanks.
James
Melbourne
Posts 49
James replied on Thu, May 18 2017 12:39 PM
I downloaded and found it to be totally unusable with my new Essence II running from iPhone 7.
  1. Using TuneIn it repeatedly turns itself up to Maximum volume causing most of the neighbourhood to think we had been nuked as the Lab5's exploded with Wagner
  2. The other main thing I use the Essence for is running the Line In from our TV.  For some reason the new App seems to stop the Essence detecting the line in and constantly goes to Bluetooth which means when I get an SMS my Lab5's sound like like the bells of St Mary live in our back living room
I tried to fix all this up through the settings, and system menu's but they are soooooooo slow, I gave up in the end.  So all in all the new App for me is unusable, and I have no desire to try it with Spotify or similar just out of interest in case it blows my speakers.
Back to the old App for me
Sandyb
Posts 2,186
Sandyb replied on Thu, May 18 2017 1:23 PM
agree with that for the most part......i down have that much experience of the Spotify UI, and while it is great to have the range of music sources that they do have, i'm not sure if its implemented in the impressive way (UI and functionality wise) as many B&O customers would like......anyway, that may all come to the B&O experience, though it is difficult to do in a long lasting way given the streaming services can change and make demands over time......as for 3rd party API's, if thats a stable route to what we want, then you may well be right, not an expert in this regard......
my comment was more at some suggesting using the B&O X app when out and away from home equipment - which i don't think is a use case B&O are trying to provide for app-wise.....
MrAndersen
Posts 226
Hi James
I'm very sorry to hear about your poor experience. Of course we would like to find out what went wrong and fix it. Could i persuade you to write a feedback from the app or to appsupport@bang-olufsen.dk.
I'm sorry for the trouble.
Thomas, Bang & Olufsen
MrAndersen
Posts 226
Hi Irvine
We have implemented support, but DLNA and TuneIn favorites are not yet working. It has proven much harder than anticipated since it is implemented in a completely different way on mk1 than on the newer products. We're working on it but it will not be ready for the next release. We're still contemplating to release it without these two core feature in the first version, but haven't reached a decision yet.
Sorry for the wait.
Thomas
Sal
California, USA
Posts 1,197
Sal replied on Thu, May 18 2017 3:21 PM
I would suggest to the B&O developers to NOT withdraw the availability of the BeoMusic app prematurely. Leave the BeoMusic App alone on the App Stores for a while longer until the X App gets on its feet and is relatively stable, usable, bug free with the basics. Even a handful of customers with poor experiences and no way to redownload the BeoMusic App isn't great news for B&O.
To reiterate, I'd suggest not pulling the current BeoMusic App at least a few more months longer. I know I'm going to download and keep a copy of the iPhone App on my Mac from here on in just to have it in case I have to revert back due to something inopportune happening with the X-App.
I am aware that one doesn't have to delete the app, but I've known accidents to happen where for one reason or another the app is deleted and there's no way back.
Millemissen
Flensborg, Denmark
Posts 14,680
I would second that!
No need to hurry about removing it, before the X-app is definitely 'finished' imo.
By the way - once you have downloded/'bought' an app, it is still there in your purchages.
I just downloded the (very) old BeoPlayer app, which was made for the old iPhones/iPods, when used with the BS8. This is not in the store for general downloading anymore.
abyss
Posts 47
abyss replied on Thu, May 18 2017 9:41 PM
I agree with Sturock, kill the volume control GUi. That would give more space for more useful things. I drew a 10min-sketch (sorry, very poor quality) just for the sake of a discossion
Millemissen
Flensborg, Denmark
Posts 14,680
No sketch, no applause.
P.S. The volume gui/wheel is great - keep it, definitely!
abyss
Posts 47
abyss replied on Thu, May 18 2017 9:55 PM
I wouldn't, just for the sake of usability, but then, i'm a very pragmatic person :-)
here's the sketch, just for fun...
abyss
Posts 47
abyss replied on Thu, May 18 2017 9:56 PM
abyss
Posts 47
abyss replied on Thu, May 18 2017 9:59 PM
abyss:
still fighting with the file :-)
abyss
Posts 47
abyss replied on Thu, May 18 2017 10:00 PM
Millemissen
Flensborg, Denmark
Posts 14,680
Means no volume control at all ;-(
Beroli
Germany
Posts 316
Beroli replied on Thu, May 18 2017 10:25 PM
Sal:
I totaly agree with that. Currently the new X-App is just another Deezer-optimized-App - and in my opinion, for my daily tasks - not even a good one -yet. I am a big fan of the luxury sleek looking old BeoMusicApp. The only thing I've really missed is the removed landscape mode. Now with the new App, if I want to listen to my chosen Deezer content only, it is nearly impossible to find my own favorite Deezer-playlist, nor -Artists. There is no alphabetical order (artist-album) anymore. The only thing you can do, is swipe, swipe and swipe through stuff/tiles you don't want to listen to right now. Even the Deezer-App itself is able to present at first sight or tap my own lists, albums and artists. Why do I need to scroll down trough recommendations first? Dear Mr. Anderson, you wrote that some important things for some users, like DLNA-support and the all-over-search will be not supported in the current and maybe the next upcoming version and still B&O decides to move forward the official "killing" of an App which is currently working very well.
Don't get me wrong, it was overdue, that B&O is finally catching up in the software-development-department and I am very happy about that. I see how B&O is improving fast, especially with the BeoSound Moment. Why not developing the new app in the same way, like you did it with the 2.x-version for the Moment - with the support from the crowd and beta-groups? I am a proud and a very active beta-tester, because I wanted a working BS-Moment and that the device survives.  A new App which binds all devices and sources together, great idea - but you are not finished yet and pull the plug for the BeoMusicApp. Is there a other reason, than manpower? The BeoMusicApp is done and finished. Why not keeping? The fees at the Appstore are not unbearable. Maybe the real reason is to collect new user-data or -patterns with the mandatory account - just by forcing everyone to use the new app. Currently, there is a B&O-second-hand-market too. The essence mk1 is nearly useless without the old BeoMusic-App. The new App will be limited. If some owners try to sell it, there is no way for new owners to download the surely needed BeoMusic-App and no way to get "fixed-on" to the real B&O experience. But ok, let's throw away the whole perfectly well working "old" NL-hardware, before buying a new B&O-device, because the old App is not available anymore - sarcasm off. Or maybe let's do the same procedure with every new upcoming device - Create a new App, remove the old App while crippling the device. Todays procedure is not very reassuring. We bought Bang & Olufsen Devices, not BeoPlay, which is "supposed" have a shorter circle of life.
I know some of you will write, stop ranting and being grumpy - but sometimes I feel that B&O just loses the focus on their customers
Cheers Beroli
abyss
Posts 47
abyss replied on Thu, May 18 2017 10:32 PM
Millemissen:
The volume control would be the long line above the moment. Sorry did forget to mention that
Sandyb
Posts 2,186
Sandyb replied on Fri, May 19 2017 12:04 AM
Testing the beta version of the X app at the moment
Nice to have DLNA support now - I have my QNAP server showing in the X app now
Also you can remove sections of the Music screen now - if you don't want to see Deezer picks, personalisation settings allows you to hide various sections, a good thing...
With DLNA support now, Music page is a mix of Deezer stuff / sections and DLNA....not integrated in the way the Moment is
So your Deezer play lists appear under Favourite Play lists, your local ones within your DLNA section
In that regard, the tiles under DLNA are unhelpful. See the picture below - surely if those tiles showed Artists, Albums, Play lists - that would be more useful???
Thoughts welcome?
abyss
Posts 47
abyss replied on Fri, May 19 2017 7:15 AM
Agreed, and a Option in the settings where you can merge your nas with Deezer ๐Ÿ˜Ž
Kiran
UK
Posts 1,023
Kiran replied on Fri, May 19 2017 8:29 AM
X app needs to ignore photos and videos stored on the NAS and read and sort all music content better...
Regards
Kiran
Weebyx
Denmark
Posts 1,213
Weebyx replied on Fri, May 19 2017 9:04 AM
Kiran:
I Agree, this is an app used to make your experience with your B&O products better. it is not a standard DLNA browsing app, and it should categorise the music from NAS much better, and in an intuitive way. I know this is the Beta version, but it is not the correct way to just make the app an "DLNA" browser.
/Jacob
Sandyb
Posts 2,186
Sandyb replied on Fri, May 19 2017 9:31 AM
So the old BeoMusic app separated out Deezer from NAS stored music.  -  i wonder if the intention is the same with the new app.....
The Music screen looks unbalanced now - with big expanded sections for Deezer and one small one for the NAS.......is suspect it will remain this way, after all the X-app  may not be intended to fully replace a Moment......
That said, if the Deezer / NAS content is displayed separately as in the image - i think (a) the single search field should work across both Deezer and local content and (b) the playing screen should show you whether the song playing is Deezer or Local......that part will replicate the Moment a bit but i wouldn't have though too difficult........
Tassos
Athens
Posts 323
Tassos replied on Fri, May 19 2017 9:39 AM
Kiran:
Millemissen:
This is exactly what I mean. Browsing and listening to the music stored on my server and why not use me iPhone as a "Room" in a multiroom setup. Furthermore Multiroom is great but what about Multiplaces? Offering the B&O experiences wherever you are. Being able to make use of the mood-wheel while commuting, driving or why not at your office. Most of the time spent nowadays is on the street being able to use you phone as if you are in your house is the way to go for me.
Moreover having a smartphone or smartwatch working in such a way can lead to other functions.....think about music following you around the house with out having to press switches. Just by physicaly entering a room your smartwatch (you always carry it with you (that is of course if you have one) and it is always connected to your smart phone) or your smart phone send whatever they play to an essence as soon as they get connected. You would leave your living room and by the moment you enter your dressing room the living room will mute and the dressing room will be where the music is playing. The technology is there it does not cost gazillions so why not????
elephant
AU
Posts 8,219
elephant replied on Fri, May 19 2017 10:20 AM
MrAndersen:
Hi James
His #1 problem is the same bad behaviour I have twice posted about.
I think it's an iOS integration problem caused by a 2nd App overlaying its volume level over the top of the 1st App's volume setting.
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Fri, May 19 2017 10:31 AM
Sandyb:
Did you define / configure anything ? Or did it just happen magically ?
BeoNut since '75
Sandyb
Posts 2,186
Sandyb replied on Fri, May 19 2017 10:39 AM
are you a beta tester?
under Music, add DLNA, searched for servers......it took a few attempts for the search to find my NAS, the first few attempts returned nothing......my QNAP was due a reboot and firmware update....did that, and then the NAS appeared ("magically") in the X app......so in essence, didn't really need to do anything configuration wise.......
i have a QNAP 251 by the way.....
egges
germoney
Posts 303
egges replied on Fri, May 19 2017 10:40 AM
sorry folks, to me it´s a deezer app, i´m annoyed not getting rid of the deezer contents.
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound +  appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
Sandyb
Posts 2,186
Sandyb replied on Fri, May 19 2017 10:51 AM
i really think they should add iOS music, i don't get why its in the BeoMuisc app but not the new one.......make absolutely no sense.......Spotify in some form is in the new (beta) version of the X app, though i'm not a user, so haven't tried to see what that offers.....but again, utterly baffling why iOS music is not there....
in the beta version, you can disable Deezer sections by the way.......which is fine, but if all you are left with is DLNA content, it highlights the lack of iOS music........not sure if i'd expect these source issues to be fixed though - the style of the new app looks like some service integration is required, which seems much easier with Deezer than other providers, so while i share your thoughts, i don't expect the other streaming services to be added.....iOS music should be though (locally stored, obviously not Apple Music).......
Millemissen
Flensborg, Denmark
Posts 14,680
Kiran:
Yes and no!
If you would only use the app for music devices, it would be a 'yes'.
And you should be able to choose, what to display in the app - probably not an easy task for the programmers,
since this is very much dependent on the way the DLNA server acts,
However, the app is intended to be a universal app for ALL B&O devices on your NL network.
And there you'd need the 'video' and 'picture' categories.
So that is a 'no'.
In the end all depends on how much we will be able to tweak/configure the app for our personal needs and for our actual gear.
Being able to remove for example the Deezer part (if you don't intend to use it) is a start!
Kiran
UK
Posts 1,023
Kiran replied on Fri, May 19 2017 10:57 AM
Millemissen:
So that is a 'no'.
Agree. I have a lot of photos and movies also stored on my NAS ๐Ÿ‘๐Ÿป๐Ÿ’ฏ
Regards
Kiran
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, May 19 2017 11:13 AM
Kiran:
Agree. I have a lot of photos and movies also stored on my NAS ๐Ÿ‘๐Ÿป๐Ÿ’ฏ Regards
Kiran
Me too, but what would the XApp provide me on this front?
Isn't its main mission to control audio streaming of our B&O devices?
Millemissen
Flensborg, Denmark
Posts 14,680
Sal:
No need to spend time on pledging for the Beomusic app to stay longer in the store.
It seems, that the X-men have overheard/overruled our concerns.
This morning - Click to see the full picture:
Page 2 of 8 (307 items) < Previous 1 2 3 4 5 Next > ... Last ยป | RSS
