BeoMusic app is merging with Bang & Olufsen app
This post has 306 Replies | 10 Followers
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Tue, May 30 2017 7:31 PM
Today's update fixes several bugs (mine at least) and brings the ability to disable the lock screen control for those who don't like it ... not for me
Millemissen
Flensborg, Denmark
Posts 14,680
? Which version do you have ?
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Tue, May 30 2017 8:07 PM
Millemissen:
1.0.0.6764 the IOS beta
Millemissen
Flensborg, Denmark
Posts 14,680
Thanks.
Do you know when that will be out for us non-betas?
(I am (still) waiting for the iPad version, before I will switch from the Beomusic app.)
Sandyb
Posts 2,186
Sandyb replied on Tue, May 30 2017 8:17 PM
I'm getting a lot of screen freezing with the latest beta...anyone else?
MrAndersen
Posts 226
Hi Sandyb
Could you send us a feedback on this? Where does it freeze?
Thomas
Sandyb
Posts 2,186
Sandyb replied on Tue, May 30 2017 8:27 PM
I would if I could....but nothing responds...app opens OK, usually says Moment unreachable, but irrespective of that nothing responds, so can't even get to the feedback screen
elephant
AU
Posts 8,219
elephant replied on Wed, May 31 2017 5:06 AM
No problems so far
BeoNut since '75
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Wed, May 31 2017 8:16 PM
Sandyb:
1.0.0.6791 is out and may solve your freezing issue
ThatGuyFromDenmark
Posts 48
Just got the new app (Android) with DLNA support - and it works!
This app is pretty great at the moment, I'd love to see you keep up the momentum. My personal wishlist is:
  1. Shuffle function
  2. More smooth "Go to artist"-functionality. Not sure of the specifics, just something that is more smooth and "app-like"
  3. Support for podcasts (please!)
  4. Multiroom support for the new Android TVs
baronvejrup
Posts 128
I would say multiroom support for BV14 and Horizon is the most important right now.
Find me on YouTube : Bang & Olufsen Teknisk Forum : https://www.youtube.com/c/BangOlufsenTekniskForum
baronvejrup
Posts 128
baronvejrup
Posts 128
ThatGuyFromDenmark:
  1. Shuffle function
Nr 4 is the most important right now.!
ThatGuyFromDenmark
Posts 48
I know this has been discussed before, but I would LOVE to have the X-app support playback via bluetooth, as that would allow me to use just one app for the entire range including Beoplay. Right now, I have to use something else to play to my Beolit and Beoplay A2
Sal
California, USA
Posts 1,197
Sal replied on Thu, Jun 1 2017 2:54 PM
Just a tiny bit of feedback. Although DLNA shows the server in the main window, the server(s) should, I think, also be listed in the source list when you click the "..." on the upper right corner of the PLAY pane. Right now I have DLNA working on the main screen, but if I tap "..." I see only Deezer, Tunein, Line In, Spotify, Standby and Cancel. I think it should also show the DLNA server(s) as they're now sources as well.
Additionally, when will DLNA search be coming? Cool
CB
> You are Here <
Posts 1,762
CB replied on Thu, Jun 1 2017 8:05 PM
ThatGuyFromDenmark:
+1
And it's fast Yes - thumbs up
dueno
Posts 101
dueno replied on Thu, Jun 1 2017 8:10 PM
In the DLNA menu when you click on artist and you choose an artist it show you songs and not the album of that artist
And in the album list it will be better if the photo of the album is before the album name
CB
> You are Here <
Posts 1,762
dueno:
Yes, for me too, but it's normal.
You certainly can set your NAS software to propose other sort options, like artist/album, album/artist, and so on.
dueno
Posts 101
dueno replied on Thu, Jun 1 2017 8:26 PM
I use twonky
In the beomusic app it's like that. So the dlna navigation is better in the beomusic app.
MrAndersen
Posts 226
@ThatGuyFromDenmark: Shuffle and repeat is coming, has been added to the products and we're waiting for the next software release. Goto artist, we will take a look. Perhaps there are more ways to do this. You can already search and play podcasts in radio? The support is very bare bones i admit. Multiroom is coming, still waiting for the go ahead
@Sal: yes it should say DLNA, we will fix this. The products do not quite agree on what to send us for the source list, that is why it is not quite consistent yet. Search is coming, but sorry i cannot give you an exact date. First we will be adding favorites, that will hopefully help a little with the deep navigation
@dueno: This is actually something we get from the DLNA server, we just display what it sends us. In many DLNA servers this can be customized, perhaps on yours as well
MrAndersen
Posts 226
Sandyb
Posts 2,186
Sandyb replied on Thu, Jun 1 2017 8:37 PM
While the DLNA addition is useful, clearly we need DLNA search.
Also, the DLNA icons show Music, Photos, Videos......this should surely show Artists, Albums, Playlists (would have thought this change is easy to make)
With respect to search, are you proposing DLNA specific search, or unified search across both Deezer and DLNA?
Sandeep
MrAndersen
Posts 226
In the next update for DLNA we will enable you to select the top level folder. Then you can get the view you describe by selecting the "Music" folder, now it defaults to the root.
I don't know yet if we want to unify it. It is tricky. Would you want two album categories in your results, one for Deezer and one for DLNA? Or would your merge them together? When you start digging into this it becomes quite complex. At first I think we will split them up and then experiment with unified search down the road.
Reto
Zurich
Posts 43
Reto replied on Thu, Jun 1 2017 9:04 PM
Doesn't work with NL/ML Converter. Another App what doesn't work in a complex environment. So doesn't the Beolink 2 App.
Reto
Zurich
Posts 43
Reto
Zurich
Posts 43
MrAndersen
Posts 226
@Reto: Working on it as we speak, expect support very soon
Sandyb
Posts 2,186
Sandyb replied on Thu, Jun 1 2017 9:11 PM
Yes, i get that unified search is trickier, not sure of there some intelligence to be borrowed from the Moment in this regard.....
didn't quite understand the first point re DLNA.....at present, the NAS shows Music, Videos, Photos.....whether that is a function of how my NAS is configured shouldn't really matter i think, as Videos and Photos are irrelevant to the app....it would be surely do-able for the Music screen to display the next level below Music on a NAS, which i would have thought for most are Artists, Albums, Playlists....though i'd be interested if thats not the case, from other NAS users......
MrAndersen
Posts 226
@Sandyb: We will let users chose what folder to start from. So now it starts from the root, that is why it shows the folders you list. In your case you can chose the music folder and you would get the artist, album etc. at the top level. We cannot do it automatically since this might be in a different language or you might have renamed the folders to something else. This is completely customizable
ThatGuyFromDenmark
Posts 48
@MrAndersen: Great news about shuffle and repeat, and thanks for being here and providing feedback!
The "go to artist" thing is just an annoyance, when something is playing that I like, I want to be able to select "Go to artist" and see a collection of albums from that artist, most popular songs etc. - the same I would get if I searched for the artist. That would be really nice, it feels constricted at the moment without this functionality.
I wasn't aware of the podcast support, I will have a play with that. But having the option of subscribing to a podcast and having it show up with recent episodes would be nice (and doing the same on the BeoSound Moment would be really nice!)
ThatGuyFromDenmark
Posts 48
(New reply because edit doesn't work on Safari)
Holy sh*t, the podcast support is just what I was looking for! Shame it doesn't work the same on the Moment.
Sandyb
Posts 2,186
Sandyb replied on Thu, Jun 1 2017 9:23 PM
Understood, makes sense now, sounds perfect, thanks.
As for the suggestion below, the Go To Artist, and Go To Album options are brilliant in Tidal...think i've mentioned this before....
Also, as for Podcasts, fuller functionality would be a dream both in the app or on the Moment......though difficult to achieve i guess.....
CB
> You are Here <
Posts 1,762
CB replied on Thu, Jun 1 2017 9:31 PM
The new app works fine for me, but my BS35 is still unable to find the TuneIn radios after having played something from "Music", albeit via Deezer or DLNA.
I always get the message "nothing to read" Sad and have to unplug/plug to the main to be able to use TuneIn again.
It's the same with the alarm clock function of course.
MrAndersen
Posts 226
@CB: Sounds like something we should look into. Could you make a feedback from the app? Then we have the logs and your product info and it will be easier to help you
CB
> You are Here <
Posts 1,762
CB replied on Thu, Jun 1 2017 9:54 PM
Just sent the error report via the app.
Fresh restart, played a Deezer song, then tried to play a TuneIn radio. Nothing to read. --> report.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Thu, Jun 1 2017 10:16 PM
MrAndersen:
As long as processing time does not impact battery life, response time and operability then any solution can be tried, but don't forget that some of us have large DLNA libraries (35k in my case) which means that any automatic processing must be a user choice.
elephant
AU
Posts 8,219
elephant replied on Thu, Jun 1 2017 10:29 PM
Sandyb:
As my DLNA Video folder contains purchased music videos and rips of my DVD music such "Diana Krall Live In Paris" I would like to be able to play those media types so I can hear them even if I can't see them ... but I can live this being at the bottom of everyone-else's list:
BeoNut since '75
Millemissen
Flensborg, Denmark
Posts 14,680
Exactly the same happens, if you try to use your NL-tv as the renderer for the movies/video clips.
elephant
AU
Posts 8,219
elephant replied on Thu, Jun 1 2017 11:12 PM
Millemissen:
That does not mean the use case is invalid Stick out tongue
BeoNut since '75
Peter the Biker
Eastwestfalia
Posts 944
Another little bit of good news for me: BeoSound Essence 1st generation is supported. It is my "Lord of the Penguins".
Peter the biker
Page 4 of 8 (307 items) « First ... < Previous 2 3 4 5 6 Next > ... Last » | RSS
