As a reasonably experienced electronics engineer (40 year plus) does anyone have details of how to derive the switch-on trigger signal for thisamp. Adaptors available but prohibitively expensive for just one unit so obviously I can wire in Phono leads to the Left and Right POWERLINK socket on the amplifier BUT it needs a trigger which normally comes via the Powerlink cable from a B & O system-my guess is tha the IR link socket could possibly provide the appropriate DC trigger signal? Any info appreciated,
RAY Bown
Do you want to just use the amp as slave from a non B&O source?
I think if you connect a ML ir sensor to the ir socket,you can turn the amp on and off manually and via remote(B&O) control?
Otherwise,you can trigger the amp by applying say 5-6 volt between pin 1(+) and pin 2(-)of the powerlink socket.
Does the source equipment provide any "on" voltages anywhere that could be adapted?
What are you attempting to do?
Regards,
Nick
Thanks for that, Nick-Sounds Heavenly provide a Powerlink to RCA Phono(2) powered trigger cable. They state there is NO 5vdc source on the 1657 amplifier so they provide a separate mains adaptor to provide this trigger voltage. This voltage and where it is applied was the answer I needed-I WAS ABOUT TO EXPERIMENT WITH a normal 5vdc USB type mains adaptor, which should do the job, hopefully!
All I want to do is use it as a slave amplifier-volume, etc will be controlled from the source. One anomally with setting the amp up as described seems to be that the IR link (normally used with a BEO4 REMOTE) will not function, according to information I have received-however this will be unnecessary anyway!
