I know that from here that people can access their NAS content on their say A9 or BS1?
how do you do it?
Ie, if i tap the A9 and change the source, how is the NAS source set up for the a9 to see? I can't seem to see it in the settings
Thanks in advance.
Hi Michael,
Are you sure (accessing "from" your device) !?!
I use the DS Audio app (Synology) to access the content of my NAS, and then choose from this app to stream to the BS35 : it's not equivalent...
This is what I see on the screen of the BS35: "Music stream"
Regards
Kiran
Born in NL; I ride ML
Hi Kiran,
You also access your files from the app, not from the device...
My Synology NAS is not seen by the X app, be it on iOS or Android... or is not set correctly to do it ?
the music-app also shows, at least here, my NAS. but how would one navigate through the NAS with an e.g. BS1???
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound + appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
Kiran:Beta version of X app can see my NAS... Regards Kiran Born in NL; I ride ML
CB:You also access your files from the app, not from the device...
CB: My Synology NAS is not seen by the X app, be it on iOS or Android... or is not set correctly to do it ?
Kiran:Have you checked the setting and enabled DLNA on your NAS?...
CB:Are there things to set in the X app? (DLNA is already OK with my NAS, all other apps see it)
BeoNut since '75
elephant:It's in the TestFlight instructions
