Hello there;
is there an XML for Yamaha RAV503 for an Yamaha AV Reciever available?
Thanks a lot =)
Great forum here!
Here are the lintronic codes....
716122133101026000000
Perhaps it helps?!?
These are all 32 bit NEC protocol codes which are easy to make into a XML file because NEC is one of two protocols support in the firmware of the Beo5/6.
You also sent me an email on the same subject which I will reply too later.
Regards Keith....
