Try to open the tablet and remove the battery for a couple of minutes. If this doesn't work then you need to ask your dealer to replace the tablet.
Do not open the unit under warranty conditions.
As Lyle mentioned, contact your dealer and they will take the necessary steps or replace your Jukebox.
He needs the complete Moment (Jukebox + Soundheart).
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Regards
Kiran
Born in NL; I ride ML
Thanks. it had to go in. apparently bricked by the update. i got it back after two weeks and now it will connect to wi-fi, but not beoportal, deezer or tune in. all was fine before this.
i tried moving it to a fixed IP address, but no luck. i can play music from my DLNA, but it will not log into deezer (failed login) or check for software updates (unable to check for software update).
sigh.
