Random Beosound 9000 purchase
This post has 13 Replies | 0 Followers
Tucker
Ponte Vedra Beach, FL, USA
Posts 439
Tucker Posted: Wed, May 24 2017 8:58 PM
Hello!  So I stumbled across a Beosound 9000 in an estate sale auction the other day and maybe I was a bit ambitious, but I bought it...  ...sight unseen...  I think for the price I will be alright.  They say it powers on and seems to function, but they had to speakers to test it.  I am heading to pick it up this weekend.  Anything I need to look for on it?  Anything I need to know about transporting it?
Thanks Beofamily!
-Tucker
Beosound 9000 MK III, Beosound Century, Beogram 5005, Beolab 8000, Beolab 5000,  Beolab 4000, Beolab 5, Beovision 8, Beovision 10, Beovision 5, Beoplay A2, Beoplay E8, Beoplay H6.
Duels
England
Posts 2,553
Duels replied on Wed, May 24 2017 9:05 PM
You can transport it easily. There are no transport screws. But there is a small plastic tool you should try to get hold of as you will need it to ensure the placement screws are adjusted correctly when you get it home. Also, if it is a pin-protected model don't forget to get the PIN code!
Duels
England
Posts 2,553
Duels replied on Wed, May 24 2017 9:06 PM
.....and congratulations on your new acquisition.
Tucker
Posts 439
Tucker replied on Wed, May 24 2017 9:14 PM
Thanks!  In the event that it is PIN protected, is there a way around that if they do not have the PIN?  I was not aware they had that option.  I highly doubt they would have the PIN considering its an estate sale...  But lets just hope it is not PIN protected...  :)
Duels
England
Posts 2,553
Duels replied on Wed, May 24 2017 9:27 PM
The later 9000 models have the PIN code. I believe a dealer can provide a master code if you don't have the PIN. However I suspect that they would have to check with B&O that the unit wasn't reported stolen first (otherwise the PIN protection would be pointless).
Perhaps someone else can confirm this?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Thu, May 25 2017 9:04 PM
Support the glassdoor. Take some bubblewrap or foam to put between the aluminium surface and door.
Otherwise you might break the plastic part inside the hingegear.
According to B&O you are allowed to open the glassdoor by hand to remove the cd's when the BS isn't attached with it's powercord.
But the plastic insert becomes brittle over the years and can break.
Replacing involves a complete motorgear which is rather expensive.
Tucker
Posts 439
Tucker replied on Fri, May 26 2017 5:21 PM
Thank you so much for the advice!  I will be sure to take care with the glass door.
Tucker
Posts 439
Tucker replied on Tue, May 30 2017 3:08 PM
Well, I picked it up!  Seems to be in excellent shape.  Haven't had time to do much other than plug it in and make sure it powers up.  The door seems to function smoothly as does the CD mechanism.  Just need to wire it up and see if I can get some sound out of it!
Is there anywhere to run a serial number to see more details about it?  such as year of manufacture?  Any easy way to tell MKI vs MKII vs MKIII?
Thanks!!!
Beobuddy
Posts 3,972
Beobuddy replied on Tue, May 30 2017 4:37 PM
Behind the controlpanel (which you can lift out),  you will find the serialnumber and typenumber. The typenumber indicates the mark.
Tucker
Posts 439
Tucker replied on Tue, May 30 2017 4:48 PM
Thanks!!
Tucker
Posts 439
Anyone have a spare remote control they would want to get rid of? Big Smile
Tucker
Posts 439
Tucker replied on Tue, May 30 2017 11:16 PM
So the type # is 2563.  This would be a MK II, correct? Sorry for all the questions, I was just super excited to get this thing!
petermc
Australia
Posts 128
petermc replied on Wed, May 31 2017 12:20 AM
Might have a spare Beo4 you can have.
PM me your details and I'll see what I can find.
Peter
Tucker
Posts 439
Tucker replied on Wed, May 31 2017 12:38 AM
Peter, THANK YOU!  I just PM'd you. Smile
Page 1 of 1 (14 items) | RSS
