Regards
Kiran
Born in NL; I ride ML
Hi kiran
open back of the unit...take srewdriver ..fix it :)
no problem.. :)
The left hand door looks about ready to fall off sir!
Has it perhaps become dislodged from it's guide/holder?It should simply snap into place.
The clunking sound is that of the safety clutch,which cleverly prevents the motor control becoming damaged if the doors are impeded.
Be careful about attempting any adjustments,as the door alignment is quite fiddly to get "just right",and being B&O it has to be that?
Regards,
Nick
