Hi all
Is it possible to dimm a KNX Actor through the BLGW and Beolink app by just sliding a slide? And, will the level in the app be adjusted if it's changed on the KNX side?
I'm wondering if I should upgrade my MLGW to a BLGW in regards to my KNX installation, but unfortunately I hardly can find any information about the interaction with KNX.
Thank you so much for any hints or comments
Regards
Reto
Eclipse 65V1-32Beosound M5Essence MK2BLI
Great, found it (https://www.youtube.com/watch?v=JAXx4tS1hMU).
Thanks a lot for the quick response
