Can a Beocenter 8000, control a Beogram 8000?
This post has 3 Replies | 0 Followers
beo3000
Posts 109
beo3000 Posted: Sun, Jun 4 2017 10:33 PM
if you have an appropriate cable can the Beocenter 8000 make the Beogram 8000 start and stop?
any info much appreciated Big Smile
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Jun 5 2017 10:05 PM
Now you don't see many Beocenter 8000s around! But the answer is yes - it will operate a Beogram 8000 - you can stop and start it and advance and retreat the arm by remote. It will operate any of the Datalink fitted turntables but has a built in RIAA so only use those decks without one fitted. The 8000 will be fine.
The Beocenter 8000 was interesting as it was a stripped out 8500, itself a stripped out 9500. I don't think I have ever seen one so good to know at least one is still in use!
Peter
tournedos
Finland
Posts 7,357
tournedos replied on Mon, Jun 5 2017 11:06 PM
Peter:
I have one as well. Nothing wrong with it as long as you don't need Powerlink. Frankly I also find the dark gray panels better looking than the brushed aluminium panels on a 9000.
--mika
beo3000
Posts 109
beo3000 replied on Fri, Jun 9 2017 1:20 AM
Thanks! very informative Big Smile
Page 1 of 1 (4 items) | RSS
