Use both Powerlink sockets Beolab's
This post has 5 Replies | 0 Followers
Desmo
Posts 27
Desmo Posted: Fri, Sep 7 2012 8:26 AM
I was just wondering how the powerlink sockets of the beolab speakers works.
I have beolab 1's, which has two powerlink sockets for deasy chaining the speakers.
If I look in the manual it says you can connect the beosound to any of the powerlink sockets.
So this means there is not a powerlink IN, or Powerlink OUT socket?
If this is true, I would be able to connect 2 sources to my beolab speakers.
If this is possible, what would happen if both sources are on?
Will it overblow the speakers?
Any experiences about this?
Stan
Chicago-area USA
Posts 869
Stan replied on Sat, Sep 8 2012 3:38 PM
I seem to recall that there was a recent thread that suggested this as a solution for allowing both masterlink and local audio sources in a room. If both are active it probably picks one - or once it "sees" audio on one of pl ports, it stops looking. Generally, modern beolabs have many safeguards so they are difficult to break just by hooking them up wrong.
Stan
tournedos
Finland
Posts 7,357
Stan:
They aren't that clever. There is only one Powerlink connection to the speaker electronics. If the speaker has two PL sockets, they are simply connected in parallel (nothing more than a PL 'Y cable', or PL splitter, built into the speaker).
If you connect a source to both of them, all kinds of funny things can happen depeding on how the sources are implemented internally. The speaker probably won't care, but when one of the sources is on and the other off (or muted), the former will be forcing PL control signals into the latter. I don't think anything will be damaged, but it's not something I would try myself.
--mika
hfat
Vienna, Austria
Posts 663
hfat replied on Sat, Sep 8 2012 5:38 PM
Some time ago I had two sources connected to BL1s. But sound quality was rather bad, especially bass was almost completely lost. My experiences are that it does not work for ICE based speakers.
hfat
beoaus
Posts 177
beoaus replied on Sun, Sep 9 2012 2:46 AM
I still have local and ML sources connected to Beolab 1's. I used to have a manual powerlink switch to manage the change over (now I change the cable and rarely at that).  For a time a BS9000 connected direct to the Beolab1's sounded better than when it ran through a BV7 sound processor. Also useful for testing other B&O equipment.
As was mentioned above the Powerlink sockets are in parallel.
beoaus.
Desmo
Posts 27
Desmo replied on Sun, Sep 9 2012 6:50 AM
beoaus:
beoaus.
@beoaus: that's exactly the reason why I would like to give it a try.
I'm just curious for the difference in sound quality directly from the beosound vs beosound through the surround processor.
But I'm not sure if I would like to send a left right signal and 5v input into the other source.
Page 1 of 1 (6 items) | RSS
