Hi,the obtrusive Beovirus is bothering me again... and currently he likes a Beocenter 8500, too. Are the grey covers on the Beocenter 8500 made of metal or is it plastic? Does anybody have a good photo of a Beocenter 8500 to see the grey color?As far as I know it lacks two way infrared, too, right?
Hi TWG,
The 8500 covers are matt grey metal, very "1980's"! I have the matching Beomaster 3500 at home, personally I love it but it is very much a matter of taste.....
Beocenter 8500 does only have 1 way remote control. I think only the "stacking" Beomasters (eg. 5500, 6500, 7000) had 2 way remote control. I found the 2 way remotes quite annoying, which was why I sold my 6500 system (the MCP remotes keep reporting "No Signal" when the batteries go flat or the range is too far).
Kind regards, Steve.
Steve.
www.soundsheavenly.com
The Beocenter 9500 had 2 way remote control via Beolink 5000 or 7000 remotes.
Regards Graham
Thanks Graham!
The BeoSound 2500 and early Beosound 2300 were also 2-Way capable
Ralph-Marcus
Thank you all for your help :)
