Hi All
Having lost Beoconnect connection, I had to perform a full recovery of my BeoSound 5.
Now I can connect via BeoConnect, but all of the Radio stations have disappeared.
Thought it was a registration problem, but the MacOS Beoconnect says registration is now not needed and the windows Beoconnect version has no registration options.
In desperation I phoned my friend who also has a BS5, sadly he reported that his net radio has not connected for months and he has given up with the thing :(
Any ideas Beoworld experts?
If you can, have a look in this windows file structure iirc, there may be some *.ibx files in a backup file.
I don't have access now to run through it and give a more definitive answer.
Alternatively, if you can install and run the old beoplayer on a PC, register and connect to the BS5, this may activate the radio stations. Not very intuitive but that's B&O for you.
Takes a couple of hours before the radiostations are back again
koning:Takes a couple of hours before the radiostations are back again
