After 30+ years of service, my Beomaster 2000 programming lid has failed. The plastic arm that is connected to the metal cover and carries the spring has snapped. Has anyone been able to repair this arm?
Excellent. Is there a brand of expoxy you can recommend?
JB Weld works great!
Thanks everyone for the info/encouragement. Used Loctite Epoxy. Cure time will end later this evening. Initial results seem encouraging.
Time Gents....I think I nailed it. Thanks, Lads. Holmfirth.
