Beosound 5 encore with external DAC
This post has 4 Replies | 2 Followers
gebi
Posts 2
gebi Posted: Thu, Jun 8 2017 10:58 PM
Hi
I'm considering to buy a second hand BeoSound 5 encore. For the best audio quality I'd like to use an external DAC.
Is it possible to connect an usb-DAC to the encore ? I guess this is not supported......
Hungedu
United States
Posts 165
Hungedu replied on Fri, Jun 9 2017 4:12 PM
I doubt that it's possible. The USB port on the Encore is for music storage only.
BeoLab 5, BeoVision 7-55 MK2, BeoSound 5 Encore, BeoSound 9000, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, BeoLab 7-6, BeoSound 8, BeoTime (analog clock), Beo 4 remote.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi gebi,
Hungedu is correct, Beosound 5 Encore doesn't have a digital output.  Beomaster 5 would be a better option if you wish to use an external DAC, as this has a co-axial digital output.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
seethroughyou
UK
Posts 999
Even with a Beosound 5 and Beomaster 5, I wouldn't bother with an external DAC and deem it to be a waste of money. This is to my mind audiophile nervosa and I've yet to see any evidence that a person blind folded could reliably and statistically hear a difference between a competently designed machine with an inbuilt DAC and an external DAC costing tens of thousands of dollars. They often have the same chipsets as the cheaper DACs you find in your TV, DVD, CD player. I have listened to some of these super expensive DACs and I couldn't hear a difference even after concnetraring very hard for several hours. NOS DACs do sound different but only in as much as the treble top end seems slightly rolled off. I would save the money, spend the bulk of your budget on the 'best speakers' you can afford and place them carefully in your room.
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Millemissen
Flensborg, Denmark
Posts 14,680
I happily agree on that!
And avoiding the hassle of having to control volume on an external device and of connecting speakers there, is worth a lot.
@gebi Get better speakers/the BL's, that will fit your room...and enjoy the Encore.
Page 1 of 1 (5 items) | RSS
