Moment will not check for software update
This post has 4 Replies | 0 Followers
johnbrks
Posts 53
johnbrks Posted: Fri, Jun 9 2017 5:27 PM
My moment got bricked when the pushed out the last software update.  I just got it back from service.  Now during the set up it says it cannot contact beoportal.  it did see my DLNA server and processed.
However, now i get the error that it 'cannot check for software updates', even when i tell it to check.
Any thoughts?
(connected via wi-fi, though i tried plugging in ethernet with no change).
andy_js
Englandshire
Posts 223
andy_js replied on Sat, Jun 10 2017 2:56 PM
Have you tried a factory reset?  That always solved my connectivity woes.
johnbrks
Posts 53
johnbrks replied on Sun, Jun 11 2017 1:14 AM
i tried that initially, but it hung when trying to connect to beoportal and would not proceed past that.  i tried doing it hardwired to my router and it still said it could not contact beoportal.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Jun 11 2017 6:19 AM
johnbrks:
Failing to connect to Beoportal always were network issues in my setup.
mostly a reset of the router resolved it, sometimes a simple detach/attach of the LAN cable was sufficient
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Jun 11 2017 8:17 AM
johnbrks:
I have had this beoportal hung state at each factory reset, you just need t be very patient and it will resume after 20 to 30', I don't remember precisely, but it resumes at the end of the day.
Page 1 of 1 (5 items) | RSS
