Hi, the latests BeoPlay App claims it is compatible with A6, however, it cannot seem to find my A6? It is just searching forever..
Has anybody successfully connected to the A6 with BeoPlay App ?
/Jacob
Weebyx:Hi, the latests BeoPlay App claims it is compatible with A6, however, it cannot seem to find my A6? It is just searching forever.. Has anybody successfully connected to the A6 with BeoPlay App ? /Jacob
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hiort:It is just searching forever..
Same here.
In the App update comments you can see that A6 and A9 are supposed to be managed by the app
Hiort:I tried now and the Beoplay app find my A6 but there is no tonetouch feature.
No luck here, just searches.... I have the latest sw in the A6.
did you do something to get it to find it? Restart, was it on/off?
Weebyx:No luck here, just searches.... I have the latest sw in the A6. did you do something to get it to find it? Restart, was it on/off?
Hiort: Weebyx: No luck here, just searches.... I have the latest sw in the A6. did you do something to get it to find it? Restart, was it on/off? Just searched and it showed. It was off.
I really really hate how different the same B&O devices works together with the B&O apps !!
Tried it for fun right now: could not find my A6 with latest FW that was actually playing, 2 meters away from me. It did find, though, A9 on standby in the other side of the apartment.
Not sure how much testing these apps undergo before releasing...
