To charger, I have used 400w power inverter to charge shaver when camping outside. In other days, I will use it to charge laptop, phone and camera battery in car. The method for us to use this tool is to connect it with car cigarette lighter charger outlet. If you need to catch more information about this charger, you can search bestekmall on Google. Wish this tip is helpful to you. Best regards.
Rorence:To charger, I have used 400w power inverter to charge shaver when camping outside. In other days, I will use it to charge laptop, phone and camera battery in car. The method for us to use this tool is to connect it with car cigarette lighter charger outlet. If you need to catch more information about this charger, you can search bestekmall on Google. Wish this tip is helpful to you. Best regards.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
I guess that belongs here:
http://archivedforum2.beoworld.org/forums/p/14404/204381.aspx#204381
There is a post with almost the same words.
Hey
I am sorry to hear that BeoSound 5 not supported by Spotify. However, you can solve it by using TuneFab Spotify Music Converter and converting to common used format like MP3 so that it will be compatible on BeoSound 5.
B&O did offer a 20% discount on the Moment for existing BS5 owners after Spotify's announcement - but then the Moment was discontinued over night...
Some of us where hoping that they would issue a new sw with support for Deezer - because they have everything in place, legally and technically, to do so - except the willingness, I guess.
Roger
Still no new audio system in the pipeline roger?
Roger: ....issue a new sw with support for Deezer - because they have everything in place, legally and technically, to do so - except the willingness, I guess. Roger
I guess it is more the trouble of having to maintain yet another sw platform, that holds them back.
And the BS5 is not a NL compatible product - wouldn’t quite fit in to there current product line.
One might say....then make it NL compatible.
This surely would be possible (would need new updated hardware), but would be rather expensive (all costs considered)...
.....and will probably stay a dream not coming true.
I doubt that such an (relatively) expensive product would sell enough - now that people have gotten used to handheld screens.
Roger:B&O did offer a 20% discount on the Moment for existing BS5 owners after Spotify's announcement - but then the Moment was discontinued over night... Some of us where hoping that they would issue a new sw with support for Deezer - because they have everything in place, legally and technically, to do so - except the willingness, I guess. Roger
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Have you thought about breaking the DRM from the Spotify Music and then you can easy to use in Your BeoSound 5? If yes, then the powerful and professional TuneFab Spotify Music Converter is your best option!
Actually, and i don't know why, my BS5 says it has no connection...but is able to play radio from india, unbelievalble...
and entering the service menu it is succesfully connected to my wifi connection.
In spotify mode no way: it says no internet connection.
No way to change the spotify libraries *.dll ?
probably just a port has been closed or stuff like that.
any news in this chapter? actally "e-tech-b&o studying" more and more on this
thanks in advance
Alex
