Do you guys who knows if there is any case for beoplay headphones?
I just bought H9 in Feb but now it is....not that clean. Also the bag is not so handy and protective. Anyonw tried any product that could protect our headphone?????
A case would be ideal or any other tips to place it??
I didnt use a case on my H8 figuring that B&O considered providing one if required for protection.
They broke while in my backpack, I was able to fix with glue but that restricted adjusting the fit a little bit..
So I strongly recommend a case, amazon has
which are little large for H8 and way too thick but probbaly work well with the H9. Quality is good.
Many thanks bro!
I have checked many on amazon but they didn't hit me!
I just found a case, which looks really nice dont know if it is good! any one bought them????? can not see any review yet!
bycaseplay.com
Hi Joakim! Did you find a place (website or store) where to buy Bycaseplay hardcase? I have H9 and this case is the best. Can you please advice me with that?
