My B&O centre with a very helpful guy closed down and now I find myself with no instant access to help with my B&O 2300. It has been taken off its wall bracket and disassembled to dust. I did not take a photo before starting and whilst I have put it back together I can't for the life of me work out where the two male to female power leads go.
I think my speakers are the Beolab 2500 speakers. They have a DIN and a male and a female power socket.
I looked at the 2300 manual but this does not help as it not says to connect the DIN with no mention of the other 2 cables.
Advice would be much appreciated
The longest double ended mains cable goes from one speaker to the other speaker.
The shorter one goes from one speaker to the Beosound 2300.
The actual mains cable goes from the wall socket to the other speaker.
Regards Graham
Thanks. I will try that now. Fingers crossed.
All working. Big thank you.
