Funny MCP 5000 issue after changing batteries
This post has 17 Replies | 2 Followers
hew128
Posts 4
hew128 Posted: Sun, Sep 9 2012 2:51 AM
My MCP 5000 had been working fine till recently.
After using the last set of batteries for a few months, was time to change them as per routine.
With the new batteries, the MCP would only work properly after insertion of the new batteries. Subsequent use of the MCP will not work. The above would be repeated if I wanted to use the BM5000???
Initially though the batteries maybe a bad batch, so bought a few set of replacements and it was the same issue every time.
Has anyone experience the same?
Thank you in-advance for any assistance in the matter!
DMacri
United States
Posts 881
DMacri replied on Mon, Sep 10 2012 7:14 PM
Yes, I have exactly the same problem, but no answer. It is still not working.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
DMacri
United States
Posts 881
DMacri replied on Tue, Sep 18 2012 2:18 PM
I kept buying MCPs from eBay so now I have about 4 or 5 parts units. I may try to take them apart and hopefully assemble one or two using the best parts.
Dom
tournedos
Finland
Posts 7,357
tournedos replied on Tue, Sep 18 2012 3:25 PM
I'm not sure I understood the problem statement... you mean that new batteries only last for a short while, or that you need to remove the batteries and reinsert them to make the MCP work again?
--mika
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Sep 18 2012 6:56 PM
Have you checked for a bad capacitor in the MCP?
Jacques
DMacri
United States
Posts 881
DMacri replied on Tue, Sep 18 2012 7:20 PM
Is there a rebuilt kit of sorts for the MCP5000?
Dom
hew128
Posts 4
hew128 replied on Wed, Sep 19 2012 6:43 AM
Yes need to remove the batteries and re-insert them to make the MCP usable. Need to do so more or less for every command to be entered via the MCP 5000
hew128
Posts 4
hew128 replied on Wed, Sep 19 2012 6:46 AM
Only a large Philips cap near the IC, in the MCP 5000. Have not substitue it yet but tested via connecting another cap of equal value in-parallel and the same issue still there.
tournedos
Finland
Posts 7,357
tournedos replied on Wed, Sep 19 2012 9:52 AM
hew128:
That's not a conclusive test, if the old cap is very leaky and loading the circuit, adding another in parallel isn't going to improve the situation.
I never worked on an MCP 5000 (mine worked fine for the duration I had it), but this sounds like a power supply failure, or a problem in the reset circuitry of the processor, which could be caused by a tired cap... There's a good schematic in the service manual, but I'm afraid I'm not able to start guessing over it without having the unit at hand. C30 and C34 seem like the most suspect candidates. Or just a plain old dry solder.
Better start with the simple things, like does the battery holder make good contact? Don't just believe how it looks, put a multimeter on the circuit board where the wires enter and see if the voltage remains stable when the MCP lights up. The next point to check will be the stabilized +4.75V rail after the power supply. The power supply circuit is rather complex because it has very little headroom to stabilize 4.75V from just four battery cells.
--mika
Orava
Finland
Posts 991
Orava replied on Wed, Sep 19 2012 12:51 PM
I have MCP behaving exactly the same. Have changed caps, resolder and everything I can think of, no solution. If I reset uP manually, it works for a while until it goes stand-by, but never wakes up, only with reset or batterys off. So maybe there is something in circuity that raises it from sleep.
Really annoying. Hope someone knows the answer to this
hew128
Posts 4
hew128 replied on Fri, Sep 21 2012 6:23 AM
Here's an even better one!
After posting this on the forum. I left the batteries in the MCP w/o the battery cover. Initially the issue persists.
Left for it for about a week and decided to depress the buttons when I saw the replies to my original post.
Eureka, it works again???
Am theorising if the new battery's are too "strong" for it as I measured over 6V during the initial dis&re-assembly of the MCP??? Or maybe it will decide to go into a coma again when I next change the batteries ...
Orava
Finland
Posts 991
Orava replied on Mon, Sep 24 2012 10:55 AM
Lucky you Yes - thumbs up Mine have been lying around self for a while now, and I do not have Any attempt to pick it up for a trySnail
Rune Rasmussen
Denmark
Posts 6
Hi.
Did it continue to work, or did it only last a shot time?
I've got the same problem, the previously owner said he used it fine for a whole evening, just a couple of days before i purchased it, which was yesterday. I've checked the battery supply and the connection is fine, but I'm also measuring over 6 volts. Did you find out how many volts it should have?
Best regards Rune Rasmussen
Lee
Newcastle upon Tyne UK
Posts 734
Lee replied on Mon, Sep 21 2015 1:02 PM
I had the same issue with one of my Master Control Panels. I wasn't able to fix it so ended up buying another one which worked fine.
The over voltage idea is interesting...
Lee
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Sep 22 2015 7:40 AM
This is odd. I've been running the same set of batteries for two years after a capacitor change. Prior to that the MCP would drain the batteries very quickly, but it worked.
The batteries swinging too much voltage theory makes no sense to me. Fresh batteries should be well over 1.6 V.
Jacques
pepps
Kent, UK
Posts 116
pepps replied on Sat, Jan 14 2017 2:32 PM
Hello,
So did anyone reach any satisfying conclusions with this kind of problem on the MCP 5000? I have the same issues.
Reading 6V+ off the power supply which drops to 3.9V when buttons are pressed.
Some corrosion on the lower half of the underside of the main board, but not to bad. Some dry-looking solder joints too. I've not attempted re-soldering just yet.
Looking to see if anyone has anything further to help steer me in the right direction.
Thanks in advance,
Julian
Keri
Chicago!
Posts 35
Keri replied on Sun, Sep 2 2018 5:23 PM
Solved!  With qualifications, and a little help from a German website.
I just repaired a MCP5000 with this issue.. Works OK immediately after batteries are installed, but after the processor goes to sleep in a few seconds, it would not re-awaken.
It seems that the MCP5000 processor stops "strobing" the keyboard when it sleeps. Instead, it applies a set voltage to the keyboard through resistor R149, and detects a keypress with this voltage. If this voltage is too low, no keypress is detected, and the system does not wake up.
This, by the way, is not mentioned in the repair manual, but it does offer an excellent schematic of the MCP5000.
It seems that the circuit boards used in the MCP 5000, especially the keypad switch boards, absorb moisture and deteriorate. This causes discoloration of the boards, and the copper traces to corrode under the solder mask coating, leading to circuit-to-circuit bridging. This is also accompanied by a pungent vinegar / burnt smell.
Steps taken:
Replaced the electrolytic capacitors, with no effect. (some are inside the metal "can".)
Set the regulated voltage to 4.75v, according to the service manual.
Verified the system works after applying a positive-going pulse to reset pin of IC1 (pin 7),  This simulates installing batteries.
Verified the oscillator is running happily at around 400khz, both with the system running and sleeping.
Noted that resistor R149 had a significant voltage drop across it. This seemed odd for a system in sleep mode. This is what lead me to the German-language thread, where someone else had noted it, combined with the pungent smell inside the MCP5000, similar to a vinegar or burning smell. Their deduction was that the solder mask on the circuit boards, particularly the switch contact boards was causing current flow through the keyboard.  My deduction is that the solder mask is OK, but the board itself is deteriorated.
De-soldered and removed the two ribbon cables connecting the main circuit board from the keyboard switch circuit boards. Checking for resistance found the culprit - 100k ohms resistance between two terminals, which was "jittery" and varied if the ohmmeter leads were reversed.
Removed both keyboard circuit boards (don't lose the keys!) and separated them by desoldering the three ribbon cables joining them together. A further continuity check revealed the circuit-to-circuit short to be in the lower board.
Removed the protective black plastic tape from  the keypad switches, (don't lose the switch contacts!) and inspected the circuit traces under the solder mask coating by shining a powerful flashlight through the circuit board from underneath... There it was, a big dark spot near the center of the board bridging 3-4 circuit traces.  Oddly, this was not near any of the dark brown discolorations of the board itself.
OK, at this point, I have a defunct 35-year old circuit board made of unobtainium. How to best repair it?
Here are the steps I took to repair it.  Please note that this risks completely destroying the irreplaceable circuit board!!!
1- Cleaned the board with 99% isopropyl alcohol, allowing to dry. Also cleaned the non-shorted upper board, after removing the protective tape.
2- carefully abraded the solder mask coating from the affected area with a brass wire brush in a dremel tool (high speed handheld grinder). this revealed 2 corroded circuit traces. I continued removing the solder mask from the area, exposing 4 traces, and stripping it back until reaching non-corroded areas of all traces.  The bare area is maybe 15mm wide and 10mm  high.
3- with the corroded traces exposed, the dark corrosion and deteriorated circuit board bridging the traces is visible. Keeping the powerful flashlight underneath the board, I scraped out the damage between traces with a hobby knife, until all the bridging was gone. Some had extended deep into the board material, perhaps 0.2mm-0.4mm. A continuity check at this point reveals that the circuit-to-circuit short is gene.
4- with the damaged area exposed to atmosphere. I placed the stinky, discolored and deteriorated lower keyboard circuit board in an oven set to 120C for a couple of hours. My though here is to drive off any remaining moisture and kill any growing organisms within the board material.
5- After baking the damaged board, I sealed the repaired are with a few coats of nail polish which I had previously tested for continuity when dry. (make sure not to use conductive paint!) After the nail polish is dry, I re-checked continuity, still at infinite ohms. (OK)
6- as a precaution, I also baked the upper keyboard circuit board for an hour at 100C. It also has discolored spots and smells bad. The main circuit board also shows signs of deterioration, but since it is loaded with electronics, I only cleaned it off with spray flux cleaner,
7- reassemble, and viola! MCP5000 now wakes from sleep upon keypress!
Caveat:
As all three circuit boards are deteriorated, I can expect future further degradation and failures. But for now, the poor battered MCP5000 is back in operation!
Good luck with yours,
Keri
¡No entiendo Español!
NEIN! Nicht Versteh!
Я немного говорю по-русскии но не очень хорошо... и
I'm not very good at English either! Maybe someday I'll find a language I'm good at?
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Sep 2 2018 6:15 PM
Very clever! Impressed! Luckily my mcp5500 has never given problems but if it does...
Thanks for taking the time to post this.
Peter
Page 1 of 1 (18 items) | RSS
