Hello,
Does the Beovisoion 14 have the same dust (between the contrast glass and the screen) problem than the BV10 and BV11?
benoit:Hello, Does the Beovisoion 14 have the same dust (between the contrast glass and the screen) problem than the BV10 and BV11? Thanks
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
mr_anders_son:No not what I have seen!
Maybe just because they always change your set BEFORE dust can be visible
diisign.com
Bought mine in Sept 2017... no dust visible...
BV11-46 1,5 years old, no dust!
kuyttendaele:Bought mine in Sept 2017... no dust visible...
Duels: kuyttendaele: Bought mine in Sept 2017... no dust visible... Well there wouldn't be if you bought it in September 2017.
Back to the future style! It's the BV14-40 MKII with the new 8K OLED screen and full virtual HDR Motion PixelGo technology..
Anyway... Sept 2016... and no complaints about dust
