Beosound 3000 wont start.
This post has 16 Replies | 3 Followers
Joker22
Posts 46
Joker22 Posted: Tue, Jun 27 2017 4:17 PM
Hi all..
My beosound 3000 wont start playing.. cd/radio.
The standby light is on as normal.
The doors open like normal.
The "tray" open so i can insert a cd, and close fine again..
But when i press cd, nothing happen, not even on the remote.. or any other button
I have change OPTION  A.OPT to 1.. the red light flash 1 time, but nothing happens..
Any ideas ?
Best regards
Morten
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Tue, Jun 27 2017 8:34 PM
Hi Morten,
Probably the laser has gone. If not, have you tried cleaning the laser head itself with a cotton bud and some cleaner?
marexy
Posts 710
marexy replied on Tue, Jun 27 2017 8:39 PM
jap...very very common problem of these devices!
Joker22
Posts 46
Joker22 replied on Tue, Jun 27 2017 8:43 PM
Hi..
Maby i ask stupid..
But if the laser i gone, will the radio not work?
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Tue, Jun 27 2017 8:49 PM
The Radio doesn't work either?!
Okay.. perhaps a different approach.  Your button pad may be faulty...
What happens if you press Radio on the remote?
Joker22
Posts 46
Joker22 replied on Tue, Jun 27 2017 9:01 PM
Nothing,  not any buttons work on the remote eighter.
I can press sound 0 2 5 8 and get in test mode.
In test mode, i can test button pad, all works, and the remote also works..
In TM 31, factory settings, i get message TM error
When i leave test mode, nothing works..
Best regards
Morten
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Tue, Jun 27 2017 9:23 PM
Well, that's the basics covered then!  All I can think of is that the microprocessor is faulty, but I've kind of reached my limit here as I'm not an engineer.
Joker22
Posts 46
Joker22 replied on Tue, Jun 27 2017 9:45 PM
Im also totally lost..
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Jun 28 2017 6:25 AM
Joker22:
Hi all..
Any ideas ?
Best regards
Morten
I have seen 2 3000 units with defective processors, it can behave very weird when this is happening, but it is funny that you can enter service mode and so on.
Can the radio tune stations, can you delete/store new stations ?
/Jacob
Joker22
Posts 46
Joker22 replied on Wed, Jun 28 2017 6:47 AM
Hej jakob..
No, cant turn on the radio, so cant tune stations..
Joker22
Posts 46
Joker22 replied on Wed, Jun 28 2017 6:49 AM
Cant do anything, execpt enter test mode
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Jun 28 2017 6:52 AM
Joker22:
Ok, sounds like a dead processor module then. Not easy to fix, you need to find a replacement unfortunately.
/Jacob
Joker22
Posts 46
Joker22 replied on Wed, Jun 28 2017 7:01 AM
Thanks..
Do you have any ideas were to find a modul.
Morten
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Jun 28 2017 7:46 AM
Joker22:
Thanks..
Morten
Nope, you need to find another 3000 unit, that might be broken in other ways, and then swap the module.
It is also possible you use the processor modules from Beovision 7-32, I have used one of those before, it is a bit more complex, because you need to find a module from the TV that has pincode disabled, and then you need to swap the EEPROM with the 3000 software from your unit to the new unit. This is also a chance, because it could be your 3000's eeprom that is dead, but it is more likely to be the surrounding module that is dead.
The best solution is to find another defect 3000 with a working processor. Just remember that you need to have the pin code for the defect unit also.
/Jacob
3400SJ
Posts 25
Silver Member
3400SJ replied on Sat, Apr 6 2019 7:21 PM
Just repaired a dead 3000 by fitting the processor from a Beovision 7 I scrapped last week, working great now thanks for the info
Stuart
3400SJ
Posts 25
Silver Member
Stuart
Michael
Singapore
Posts 6
Hi Lee, I got a issue abit same like this, this morning when I am power on the beosound 3000, it's just work 5 seconds and suddenly switch off and the screen show nothing, after that totally can't power on, even can't show the red light, pls give me some advice. Thanks alot
Page 1 of 1 (17 items) | RSS
