Beovox 3000 type 6220 rubber surround kit?
This post has 5 Replies | 0 Followers
Beo_Jean
QC, Canada
Posts 334
Beo_Jean Posted: Sat, Jul 1 2017 2:29 PM
Hi everyone!
I would like to know if a surround repair kit exist for the 10" woofers for those speakers?
The rubber cracked on mine and need new rubber surrounds but can't find anywhere the same size.
Are they worth saving BTW??
If anyone knows the answer would be appreciated.
Thank you!
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Jul 1 2017 4:25 PM
It's a bit unusual to see these woofers with bad rubber surrounds.
I cannot help thinking if they had some unhealthy treatment at some point.
I could probably find a good pair of original woofers in the dungeons - but I don't dare think of the postage cost.
Beo_Jean
QC, Canada
Posts 334
Thanks for answering Martin,
I don't know if the speakers were beaten but other than the cracks, they seem and sound fine.  The cracks started where you have the vulcanized notches surrounding the outer side.  So I either find a surrounding repair kit or replace the woofers.
But  before investing money on them, I have a couple of questions if you don't mind answering
- Do you still have the Peerless you're advertising on Bonanza?  PM me the price if you still have them.
- Would you match these with a 1967 Beolab 5000 freshly restored?  I think the amp might be a little over powered but who would use an amp to its max rating?
I would like to keep them and have the entire system from the same era.
Thanks!
Dillen:
Dillen
Posts 13,191
Dillen replied on Sat, Jul 1 2017 7:57 PM
I would always look for the original part for any B&O speaker.
The drivers are for the most part custom produced for B&O and replacing with anything but the original
thing rarely provides good results. Even modern drivers won't work very well, really.
The T/S parameters will show why - and it's often because B&Os cabinets have a fairly low
physical volume, requiring some unusual specs of the drivers.
Beo_Jean
QC, Canada
Posts 334
Don't get me wrong, I never had the intent to replace the originals with something else.
I could see on your advertising the exact same speakers but it was probably an old add since I do not see them anymore.
But I'm still unsure if they are worth saving to match with the 1967 Beolab 5000...??
Thank you!
Dillen:
Beo_Jean
QC, Canada
Posts 334
If anyone is looking after a rubber repair kit for the Beovox 3000 Type 6220 woofer,
The only place I could find it was at QSR  (Queensland Speaker Repair)  https://qsr.net.au
And the part number is RS 222-183
Regards,
Page 1 of 1 (6 items) | RSS
