Hi
Does anyone have seen this kind of picture problem (see link) on a Beovision Avant 55"? In other words - is this normal?
https://drive.google.com/file/d/0B3LFpMFxSnYLUkpmRXA5MWlZYXc/view?usp=sharing
Best regards
Thomas
Format: ???Duration: 0.04
To me It looks like an excample , when the signal isn't strong enough. Have you tryed to see the strength for the signal for the program, when it's happening?
Unless it is a regular and concistent picture you have posted, I don't think the problem is the Avant. I suspect the program source to be the cause!
Regards
Jan Præst
BeoLap 17, BeoLap 3500, Beosound 35, BeoSystem 4, BeoPlay A2 Active, Beovision Eclipse 55, Beoplay E8 2.0, Beolap 19
The source is good and it happens, when the picture is moving.
