hanging RL 140 speakers
This post has 13 Replies | 1 Follower
godotz
Posts 26
godotz Posted: Mon, Sep 10 2012 1:40 PM
hello , anybody here has the experience of hanging a pair of RL 140 on wall ?
have ordered a pair , but started to worry about how to hang them up the wall .
what kind od hooks i should buy ?
is there any diagram to show the way of hanging .
please help . thank you .
Puncher
Durham
Posts 11,729
Puncher replied on Mon, Sep 10 2012 2:26 PM
They use their own dedicated wall brackets which allowed side to side and up/down adjustement. Just remember to use really big screws!Whistle (If the neighbours use them to hang their coats then you've probably overdone it just a touch)!WinkLaughing
Ban boring signatures!
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Sep 10 2012 2:36 PM
I tend to agree  - I would floor mount but if wall is the only option, you need the original brackets and a very sturdy wall! These are 15kg each! At least they are not MS150s!!
Peter
stefan
200 miles from Struer
Posts 2,920
stefan replied on Mon, Sep 10 2012 2:47 PM
You can order these ones:
http://radioogtveksperten.dk/tilbehoer-44/beslag-53/dreje-vaegbeslag-til-rl-140-7000-118.html
Stefan
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Agree that you need the original brackets which are considerably more substancial than the more common ones for the RL45/60/6000 models.
The wall plate is around 300 mm square to spread the weight and I had a pair for years mounted on a studwork/12.5 mm plasterboard wall with Rawlplug Intersets, no problem.
Those indicated by Stefan look ideal!
Regards Graham
godotz
Posts 26
godotz replied on Fri, Oct 12 2012 1:35 PM
thank you for your info .
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Fri, Oct 12 2012 4:03 PM
This is what you need and I'm not sure if it's complete. Wanna use that for my almost finished/restored RL140's.
Have you got the same?
Brengen & Ophalen
Søren Mexico
Mexico City
Posts 6,411
Missing the front hang piece, Leslie
Dreje vægbeslag til RL 140/7000
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Oct 12 2012 8:19 PM
Should this bracket be part of the wall mount or the speaker Soren?
Not so difficult to make one myself isn't it?
Brengen & Ophalen
Søren Mexico
Mexico City
Posts 6,411
Leslie:
It seams to be part of wall and/or stand mount, I made a pair for Martin, a lot of square and round holes as it has to fit several different mounts, but if only for wall mount it can be made simpler
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Oct 12 2012 9:24 PM
Thanks, you're my pal. My RL140's are almost finished so let's see how these wall mounts works!
Brengen & Ophalen
Søren Mexico
Mexico City
Posts 6,411
Søren Mexico:
No, its called a Standard mounting bracket  spare part # 3031116, and comes with the speaker, if the spare part manual is OK, some shops may still have it in stock. For the RL 60 they are smaller. for hanging on gypsum walls a bigger wall plate, 300 x 300 Mm, is needed
sonavor
Texas, United States
Posts 3,732
sonavor replied on Fri, Oct 12 2012 9:52 PM
On my sets of RL 140 and RL 60 speakers the bracket you show mount to either the floor stand or to the wall mount.  I never bought either of those speakers new so I can't say if that bracked was included with the speaker itself.  I bought a pair of the RL 60 wall mounts last year and was dissappointed when they didn't include the bracket. I had the brackets on the stands but I wanted a set on the wall mount too.  That would make it easier to switch the speakers from wall to floor.  So far I haven't used the wall mounts. After working with the RL 140 speakers, they are really heavy and I don't think I really want them on the wall because of the size (and weight).
If you do mount them on a wall I would like to see some pictures and feedback on how you think they sound.
Thanks,
-sonavor
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Oct 12 2012 10:03 PM
Will make a new thread about reclothing my RL140's (which I have promised to do a week agoEmbarrassed).
So many fun things to do with all my B&O stuff. This evening I finished 12 CX drivers for refoaming.
Have to find a suitable wall to see how these brackets works but not permanently since I not intend to keep them.
Will make a picture of that!
Brengen & Ophalen
Page 1 of 1 (14 items) | RSS
