I have a lovely Beomaster 4000 with blackface panel that was working all 4 speakers with speakers 1 and 2 great until I fixed the green stereo light ......now channel 2/speaker 2 set doesn't play anymore ....speakers 1 work great.......where do I look to get speakers 2 back? I heard one loud pop as volume was slid real high just once but nothing since then,,,,,,,Thanks
Chief
Have you disturbed any of the connections to the "ambio" switch which is next to the stereo lamp,or is the ambio switch "on" even?
When ambio is engaged it alters the function of the SP2 circuit creating a sort of surround sound system.
Nick
Thanks Nick....I'm 90% sure I did disturb the ambio switch....I will open up and repair it....THanks so much
