Beovox S45: 2-way or 3-way version best?
This post has 15 Replies | 1 Follower
Runeferg
Posts 10
Runeferg Posted: Fri, Jul 28 2017 11:22 PM
I'm considering buying some Beovox S45 online, but I'm a little confused which version of S45 they are. These have two metal rims on the front panel,s upper and lower part, and the speaker is 2-way. Is this version as good as  the more widely described 3-way version?
DMacri
United States
Posts 881
DMacri replied on Fri, Jul 28 2017 11:47 PM
No, sadly, they are inferior to the originals. I've had both and the difference is dramatic.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Runeferg
Posts 10
Runeferg replied on Sat, Jul 29 2017 12:33 AM
Ok, Thx :)
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sat, Jul 29 2017 3:10 AM
Note that the three driver S45 is not a true 3 way speaker, it uses the mid driver as a phase link speaker, used to fill in in a dip in response that occurs where the woofer and tweeter overlap. I think this design approach was way ahead of its time, B&O has always been good at addressing loudspeaker design issues others seem to ignore.
So, personally, I'd go with the older phase link models if it were me. But if you can listen to them your ears should guide you. Also, if memory serves the later two driver models used foam surrounds on the woofers which have likely deteriorated whereas the older models used rubber surrounds.
Jeff
Runeferg
Posts 10
Runeferg replied on Sat, Jul 29 2017 9:15 AM
Thx for your insight 😊 Is it any way I can identify the non-foam version version without splitting them open? Serial # maybe...?
DMacri
United States
Posts 881
DMacri replied on Sat, Jul 29 2017 10:55 AM
All of the old version S45 speakers have rubber surrounds and a one piece fret (grill). The newer S45 has a two piece fret and foam surrounds.
Dom
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Jul 29 2017 4:45 PM
You do however need to remember that the S45.2 (the desirable 3 drive unit model) is now getting quite old - the capacitors in the cross over may be aging and the magnet on the woofer can slip, causing the drive unit to seize. This is fixable but will either require some work or some money!!
Having said that, the S45.2 is possibly one of the best small speakers available at what is still a reasonable price. The later S55, which is a two grille model, and the MC120.2 are also super small speakers and likely to be even cheaper.
Peter
Runeferg
Posts 10
Runeferg replied on Sat, Jul 29 2017 11:24 PM
Ok, thx. I'm a newbie to B&O equipment - are these components, should I need them, available through eBay? Maybe slightly off topic, but maybe someone can recommend a LP player setup for these speakers? I've been considering the Beocenter 7007.
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Jul 30 2017 9:08 AM
The Beocenter 7007 and 7700 are the two best B&O LP based music centres. They will need maintenance so either buy a restored one or be prepared to get work done - They will need new belts for the cassette player and the electronics will often need some of the components replaced. A good match for S45.2s.
Peter
Runeferg
Posts 10
What's actually the difference between model 6302 and 6312?
Runeferg
Posts 10
Revisions i guess i should say, of the S45.
DMacri
United States
Posts 881
DMacri replied on Wed, Aug 2 2017 6:33 PM
From the description page about the original S45 in the main site products section - "...and are easily differentiated from the S45-2 as they have a protruding resin rear and no metal trim on the rear of the cabinet. Otherwise very similar."
Dom
Runeferg
Posts 10
Thx. So audio-wise i guess they are pretty much identical then?
Runeferg
Posts 10
Looking back at this thread I suppose it's rev 2, meaning 6312 I should go for. Sorry about that.
DMacri
United States
Posts 881
DMacri replied on Thu, Aug 3 2017 4:22 AM
It really depends on your installation. Sound wise, they are identical, but the S45.2 are meant to be bookshelf or stand mounted. The S45 has placement slots on the back for wall mounting. No stand option that I am aware of.
I have both versions, but I feel the S45.2 look nicer because of the extra aluminum strip on the back of the speaker.
Dom
Andrew
Frinton, UK
Posts 917
Andrew replied on Thu, Aug 17 2017 3:36 PM
Agree, also the size of the room they are in - I have a pair of S45-2's and they sounded a bit lost when I audtined them in a large room, however at home they are fantastic - same with my M100-2 - fabulous in a larger room but too big for a small room.
Page 1 of 1 (16 items) | RSS
