Speakers to 2 TVs
This post has 4 Replies | 2 Followers
quader
Posts 109
quader Posted: Sat, Jul 29 2017 6:53 PM
Is it possible to get sound connected to the avant 55 and beovision 7 40 mk3 if yes how
Help and suggestions would be appreciated
mczac
Posts 49
mczac replied on Sat, Jul 29 2017 7:21 PM
for a minute I thought that you wanted to connect same speakers to 2 TVs, then solution would have been PowerLink splitter https://almando.com/index.php/b-o/almando-powerlink-switch-stereo.html
however I think you meant just adding independant pair of speakers to these TVs, then you just need to specify what speakers you need to connect, and Steve form http://soundsheavenly.com/ will be able to help you with approrpiate cable.
quader
Posts 109
quader replied on Sat, Jul 29 2017 10:02 PM
i have a pair of Beolab 4000's and 2 pairs beolabs 8000 as well as ceiling centre speaker connected to the avant and considering in connecting same speakers to the 2nd tv in another so that i can utilise the projector
hope this makes sense
mczac
Posts 49
mczac replied on Sun, Jul 30 2017 11:54 AM
take a look at almando power link switch, it is capable of switching between 2 inputs . you might need to daisy chain each pair of speakers and connect one switch to each pair.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi quader,
This is an interesting question.  My answer would normally be: Yes, you could connect the same speakers to two TVs, but this may not be the best solution.  Extra hardware is needed (as mentioned above) which adds to the cost and complexity, whilst there may be little or no gain in doing this.
Would you be able to upload a sketch or diagram to the forum thread please (or you can email one to me via my sponsor link below if you prefer and I can upload this for you)?  We can then see the full room and equipment layout that you have and better understand what you want to achieve.  There is often a simpler solution that becomes apparent once all the facts are known! Wink
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (5 items) | RSS
