It appears that to input 'soft' buttons into the list on this version of the Beo4 you generally need to put them in the order you wish to access them i.e. no 'move' option. However I cannot seem to get 'Link' in position one which is where I want it. In my case I need CDV and Phono but the software puts these ahead of 'link' in the list regardless of the order they are put in. Is there a way around this?
Try to remove all items from the List and then add them again in the order, that you would need them.
Yes I removed all of them then re-added in the order I wanted but the SW will not let LINK be at no.1. Example, If CDV and PHONO are in the list, LINK is automatically made No.3 whichever order I put them in! There will I'm sure be a good reason for this but the MOVE option is certainly welcome in later versions.
Try deleting LINK then adding it but instead of pressing GO to add it, press 1.
Doesn't work but thanks for the suggestion.
David
frog: Try deleting LINK then adding it but instead of pressing GO to add it, press 1.
