BeoSound Overture and Non B&O speakers?
Ryan
Yorkshire, United Kingdom
Posts 32
Ryan Posted: Thu, Aug 3 2017 11:15 AM
Hi all,
I have just just acquired a 2632 model of this system and it looks stunning, but it didn't come with any speakers. I have some Microlab 8C active powered speakers and I just wondered what cable I needed in order to use these speakers with my device? Does it have a 3.5mm headphone port I can use at all?
i hope someone can provide me a link to what cables or accessories I need in order to get it to work?
Duels
England
Posts 2,553
Duels replied on Thu, Aug 3 2017 12:33 PM
Contact Steve at sounds heavenly. Site sponsor.
CB
> You are Here <
Posts 1,762
CB replied on Thu, Aug 3 2017 12:46 PM
Hi
Yes, the BS Ouverture has a headphone plug, but the best option is to use a dedicated cable, plugged on the AUX input/output.
As Duel suggest, ask Steve (the guy with the blue shirt down the page Wink )
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Thanks guys!
Hi rjnicko,
Thanks for getting in touch.  Your speakers come as a pair, with one powered speaker (which takes the input connections) and one unpowered speaker (which works as a slave from the powered speaker).
Simply connect the cable in the link below from either of the two Powerlink output on the Ouverture to the RCA input on the powered speaker, this way you can use the B&O remote (if you have one) to control the speaker volume:-
http://soundsheavenly.com/bang-olufsen/110-5-pin-din-to-twin-rca-powerlink-compatible-to-non-bo-hifi-amplifier-receiver-etc-din-to-twin-phono.html
If you don't already have the passive 2-wire cable to connect between the two speakers, please let me know.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (4 items) | RSS
