I have a beolit 1000 with a broken on/off button. Basically its not latching as the spring and latch are not in the set. Been removed probably a long time ago. Whats my options.?
fm string is broke has anyone got a string diagram for the fm part. Have already ordered new string.
aerial is broken, anyone got a spare?
also side panels are worn, anyone got spares ?
thank you and hello from newcastle england.
Sorry its the afc button not the on off but think its the same latch mechanism missing.
I understand that you need to be a silver or gold member to post wanted ads.
Ben
Which finish do you have? I do have a service manual for the Beolit 1000 and also am in the North East. Just outside Whitley Bay. You are welcome to use it. I have a 1000 in goatskin.
Peter
You are correct but the chances of finding replacements are vanishingly small so I regard it more as a cry for help!!
Its the goatskin one. With silver sides.
Not sure why it said that 3 times , sorry
Wouldnt care peter i was near archers this afternoon.
I have got the manual out for you - I am a GP and full time but if you PM me your address, I can drop the manual off for you over the w/e.
Not sure if i can send a pm peter
perhaps i could help you,i have the sides and an antenna.The sides does not look very pretty.
but i could paint them so they are going to look like this
and here is the antenna,but the last 15-20 cm are missing
maybe i can get a friend to make an top for the antenna that looks like the original.
are you interested ?
henrik.
