yes, its not supported.....not in the specs of the Eclipse anyway.....
B&O haven't implemented Atmos anywhere, so that shouldn't be a surprise..
No, there is no support for Dolby Atmos in the SoundCenter of the Eclipse.
Sure, the LG tv-part can bitstream the Atmos soundtrack, but you would need a decoder for it in the soundprocessor.
I don't expect that to happen soon!
In the meantime you could enjoy the B&O TrueImage upmixer....if you have enough speakers connected to the tv/the SoundCenter.
This - 4 years old - article tells a bit about that:
http://www.tonmeister.ca/wordpress/2013/12/06/bo-tech-trueimage-upmixing/
Beo in white is my thing
Currently own: BeoVision Avant 55", BeoLab 5, BeoLab 18, BeoRemoteOne, BeoPlay V1-32", BeoRemote4, BeoSound 3200, BeoGram 6500 (MMC-1), BeoLit 15, BeoPlay A1, LC2, BeoVision MX7000 and BeoLab 3
That's a nice setup, Erik, did you think of trying the forged iron gray colored speaker fret for the Eclipse? I'm curious how that darker color would have offset the white BL5's flanking the television.
Regardless, congratulations, and that looks great!
Only missing thing now is a white frontcover on the Eclipse ;-))
BeoNut since '75
Congratulations Erik !
Your setup, Eclipse with Beolab 5, looks really great.
Rudy
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Haha! Yes, white is my thing but I have actually ordered it with the aluminum front. The alu fronts will come in January but black works quite good.
You get the feeling that the screen just keeps going down into the speaker front due to the Bezels are so thin.
//EA
Thanks! I actually ordered the alu front but got the black one for free due to late delivery.
My dealer talked about the forged grey colour would be nice. I was also into to the Persian night blueish.
But I did the "safe" thing and went for all black.
EVA, is that a 55 Eclipse?
Looks terrific!
Impressive setup Erik,
Curious about actual details on the sound. Do you feel the Eclipse sound bar is almost unnecessary in your setup,or does it really perform as a centre channel that well? After all its about the cost of a single BL5.
Thanks Beoaus.
beoaus:Curious about actual details on the sound. Do you feel the Eclipse sound bar is almost unnecessary in your setup,or does it really perform as a centre channel that well? After all its about the cost of a single BL5.Thanks Beoaus.
Sure,
Beolab 5's are priced in Australia singularly. Say $16,000 AUD each, double for 2.
A Beovision Eclipse 65 uses the LG Panel at about $5,000 separately. Ad the BL5 speaker cost from above to the cost of the standard LG panel and you are below the cost of a 65 inch Eclipse. I know its not a workable solution and the stand is not considered, though the speaker on the Eclipse is where most of the money goes which I do need to understand. Especially for those with existing separate multi channel speaker setups, like myself.
Just my strange mind working overtime, plus its loosely calculated.
Cheers, Beoaus.
Yes, the 55". The 65" is actually Very big IRL so the 55" fit in perfect to our home.
The sound better then my Avant 55". The sound feels directed to the listener and it has a better depth. It's almost like having a pair of BL17 as center speakers and the sound image is more wider then the Avant. Like, Mikipedia, I often use the TV (center speakers) for night watching or normal TV use. Don't need to fire up the whole surround sound system. TV series and normal TV shows I use center speakers. For music I use the BL5's. BL18 I use for music for more background listning. I don't know the price for a single BL5 speakers is. In Sweden all speakers are sold in pairs. I think in Denmark price is per speaker.
beoaus:Sure, Beolab 5's are priced in Australia singularly. Say $16,000 AUD each, double for 2. A Beovision Eclipse 65 uses the LG Panel at about $5,000 separately. Ad the BL5 speaker cost from above to the cost of the standard LG panel and you are below the cost of a 65 inch Eclipse. I know its not a workable solution and the stand is not considered, though the speaker on the Eclipse is where most of the money goes which I do need to understand. Especially for those with existing separate multi channel speaker setups, like myself. Just my strange mind working overtime, plus its loosely calculated. Cheers, Beoaus.
Can one of the owners be kind enough to take a picture of the stickers on the set (speaker, stand ?, screen ?).
Thank you !
To be perfectly honest here, I have to say that my dealer initially told me a wrong quote about the Eclipse.
I just checked another french dealer with a good website and the prices are shown.
The tv is still very expensive but less than what I said and yes, even less (a few €) than the Avant NG.
55" : 8.800 € + 1.455 € floor stand = 10.255 € (with fabric speaker - extra 850 € for alu speaker).
Folks, another feedback after I had the opportunity to see the Eclipse and Loewe in person in Europe. This is just my personal opinion and I do expect some to agree and some to disagree.
First on Eclipse, I will not repeat what have been said multiple times but my new observations are design aspects. After spending almost 2 hours in front of iit and visiting 2 separate dealers. I moved between like it and not like it. Main design low point for me was the "black glass undert the speaker which seems an oddity. When the TV is switched off, it looks well balanced and aligned with the screen but when the screen is switched on, It seems out of shape with the screen as the outer doimensions are the same as the panel with siding but when the screen is on, then the black glass seems bigger then the screen and out of alignment.
TV experience is nothing more to write about., Pure LG and I did not enjoy interacting with the TV.
Sound bar is absolutely delicious and if someone does not have the B&O sound at home, this could be a great one in all product . This should also mean that the new buyer may not be as picky on small things that we oldies fuss about 😏.
On the Loewe, it looked better in poerson that I expected from the pictures and TV interactions and picture quality seemed better than Eclipse. SOund is o pretty clean and good for a TV built cannot be compared with Eclipse.
So the biggest selling point for Eclipse is the sound and biggest selling point for Loewe is the overall expernce of quality finish / design and perhaps money. If sound was my primary need, I would go with Eclipse (though still with some hesitation) and if the picture / experience is the reason to buy TV, Loewe may be better way to go.
On the 65 inch, I would personally tilt towards the Eclipse only for the reason the my wife things it will look better with BL 50 but I am turning more towards the Loewe 77 inch as the screen experience is just out of the world. No comparison between the 65 inch and 77 inch and am happy to give up the features that Eclipse brings versus the 77 inch Loewe. With the price quoted, Loewe 77 inch will only be 3500 Euro higher than the Eclipse.
Still sorting out the shipping hassles and once clear, I will move forward.
Hope that helps some.
svinaik:Sound bar is absolutely delicious and if someone does not have the B&O sound at home, this could be a great one in all product .
Maybe the Bild 7 is not the Loewe we saw.
It was a large screen mounted inside a large "bronze" trapezoidal frame
Is that the one you are thinking of ... or this one: https://www.loewe.tv/int/configure/bild-7 ?
I will go with standard motorized floor stand (tripod style) not easel stand. I would have personally preferred the Round base on the stand but Loewe is now into angular designs, not circular designs.
On the floor space issue, another way to think is that space under the Screen cannot really be used for anything in any case. So stand size should not mattter much. I did not feel stand size was any issue at all but that is just a personal opinion. Wives can be a bit more serious on these matters while husbands are generally glued to the panels.
elephant: Maybe the Bild 7 is not the Loewe we saw. It was a large screen mounted inside a large "bronze" trapezoidal frame Is that the one you are thinking of ... or this one: https://www.loewe.tv/int/configure/bild-7 ?
You may have been looking at BILD 9. I am looking at BILD 7 with dark gray color stand as in the link above.
Which country did you go to or are you in europe?
M
Mikipedia: Which country did you go to or are you in europe? M
I am currently traveling in Europe . I saw the Eclipse in Vienna and now in Amsterdam also. I visited the Loewe Gallery in Amsterdam and got the final quote on Loewe 77. I am going for it.
With the Almando Box, integration of BL 50 is no issue. Perhaps a good mix of Loewe and B&O. Loewe dealer was very knowledgeable and has been the B&O dealer also in past and at the other locations. Knew all that I needed to know to integrate B&O and Loewe.
Once I get all the pieces in place, I will share my experience and any help that I can provide to anyone wanting to walk this path.
I currently live in the Netherlands(utrecht) its 30 min
away from amsterdam, if you’d like to see my bl50’s
with my eclipse 55 pm me, you’re more than welcome.
m
hello Svinaik
congratulations with your purchase of the Loewe!
One question I have on the set-up of a Loewe TV with Beolabs: can you still use the Loewe TV as your center speaker?
I am tempted to do something similar, but distance between my beolabs is 5 meters. I fear that without a decent center speaker, this would not give satisfactory results especially for voice reproduction (eg. in movies; etc.).
Very interested in your feedback!
Jan
Hi Jan
with the Almando Box, TV will act as the center speaker and your BL 5 will work as left and right front. Actually, I saw the process on Loewe TV where the speakers setting are made. It is easy to do so.
On another positive note, I have taken the plunge and have confirmed order for the Loewe 7.77 with motorized stand and Almando Box. Total cost including shipping to USA is Euro 14,600.
PM me for any details required.
Someone who knows where to put a harddisk for recording into the 65’ Eclipse.
I have study the installation video from B&O Global training and have really no idea where it can be hidden, there is hardly any space for another wire together with the HDMI 2 cable for the communication between the soundcenter and the LG.
The only option is the USB 3 port close to HDMI 2 and there is no room in this section of the LG for a harddisk and there is a very limited canal for a wire to pass out from there together with the communication HDMI cabel.
BeoVision Eclipse 65....Front: BeoLab 50....Rear: BeoLab 4000....BeoSound 9000 Mark lll....BeoRemote One BT....BeoSound Core....BeoLab 17....BeoRemote Halo....Apple TV 4K....NAS: Synologi DS218j....Disc Player: OPPO BDP-203....Projector: JVC HD-950....Screen: Stewart StudioTek 100....HDMI management: HDFury Integral
svinaik: Hi Jan with the Almando Box, TV will act as the center speaker and your BL 5 will work as left and right front. Actually, I saw the process on Loewe TV where the speakers setting are made. It is easy to do so.
How does this work? I thought the TV will switch off its internal speaker when directing its output to the Armando Box? What you are saying is too good to be true...
Hello everyone. I'm hoping someone can clarify a couple of questions for me.
In the medium to recent past, BeoVision TVs have automatically adjusted their picture settings based on ambient lighting conditions.
1. Does the BeoVision Eclipse include this capability?
I've read a couple of reviews/articles that refer to some "Expert" picture settings or profiles.
2. What is the role of these settings on obtaining accurate/lifelike/good/best picture reproduction? Do they have to be manually selected?
Thanks, everyone, for your time.
Scott
