Hello all!
So I recently changed my set up in one of the rooms a bit and now the right Beolab 8000 constantly clicks on and off...
It may be due to how I changed the set up... I have a Beosound 9000 with each of the powerlink outputs going to a Beolab 6000 then a Beolab 8000 connected to each 6000.
Any reason why the one 8000 would keep clicking on and off with the Beosound 9000 turned off?
Thanks!
-Tucker
Beosound 9000 MK III, Beosound Century, Beogram 5005, Beolab 8000, Beolab 5000, Beolab 4000, Beolab 5, Beovision 8, Beovision 10, Beovision 5, Beoplay A2, Beoplay E8, Beoplay H6.
Hello Tucker,
This could be a cable problem, if you lose the yellow wire (pin 4) in the Powerlink cable, this can cause this issue. Are you able to swap the cables over to see if the fault "moves" with the cable or stays with the same speaker please? Otherwise, please can you check the switch setting (near the input sockets), the switch should be set to "L" or "R", not to "Line".
If you find a faulty cable, please feel free to click on my sponsor link below, as I stock the Powerlink mk.3 cables you need in a wide choice of lengths
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Thanks Steve! I will give that a try!
