Hi All, I have followed the instructions in the B&O FAQ by setting my BeoRemote One in Beosound mode.
However, I cannot control my Moment, not even adjusting volume control.
Has anyone had any luck on this?
Beolab 5 Final Edition, Beosound Moment
Maniax: Hi All, I have followed the instructions in the B&O FAQ by setting my BeoRemote One in Beosound mode. However, I cannot control my Moment, not even adjusting volume control. Has anyone had any luck on this?
Do you have the service panel on or off the Moment when you try ? The IR is disabled when service panel is off..
/Jacob
Weebyx: Maniax: Hi All, I have followed the instructions in the B&O FAQ by setting my BeoRemote One in Beosound mode. However, I cannot control my Moment, not even adjusting volume control. Has anyone had any luck on this? Do you have the service panel on or off the Moment when you try ? The IR is disabled when service panel is off.. /Jacob
thank you. Yes I tried it both with the service panel on and off and there was no response.
im wondering whether I configured the remote wrongly.
