Beolab 3 to LG TV connection
This post has 17 Replies | 3 Followers
diggs2701
Miami
Posts 29
diggs2701 Posted: Thu, Aug 10 2017 2:27 PM
What is the best connection for a Beolab 3 to LG TV? Are there specific cables that have Powerlink to 3.5mm or RCA connections? Does it sound good? Thanks.
benoit
France
Posts 646
benoit replied on Thu, Aug 10 2017 2:30 PM
I guess that Steve from Sounds Heavenly can perfectly do this for you... Just look down ;-)
Stan
Chicago-area USA
Posts 869
Stan replied on Thu, Aug 10 2017 6:04 PM
If the TV doesn't have a variable audio output (a couple of mine do not), then you might look into the BeoPlay connection hub (which seems to be sold out on the BeoPlay site, but other sites have it - at least in the US).
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi diggs,
Stan and Benoit have covered both options perfectly:-
1) The only way to connect the speakers directly is if the TV has a headphone socket, as this is the only way that the speaker volume can be controlled from the TV remote.  (some TVs have a separate headphone volume setting in the menu, instead of using the main volume buttons on the remote - you can test this by plugging in a pair of headphones).  Please use this cable to connect a pair of Beolab 3 speakers to the TV headphone socket:-
http://soundsheavenly.com/line-in-connection/70--trs-2x7pd-.html
2) If the TV only has an optical output then a Beoplay S8 Connection Hub is needed (£149 GBP from your local B&O store).  This converts the light signal from the optical socket to an electrical signal and allows the TV remote to control the speaker volume.  Please use an optical cable from the TV to the Hub:-
http://soundsheavenly.com/input/149-premium-braided-toslink-optical-cable-with-metal-plugs.html
You now just need one RJ45 splitter and two Powerlink cables to connect two Beolab 3 speakers to the output of the Hub:-
Splitter (1 required): http://soundsheavenly.com/bang-olufsen/27-rj45-powerlink-compatible-splitter-new-powerlink-to-two-8-pin-din-powerlink-compatible-sockets.html
Cables (2 required): http://soundsheavenly.com/powerlink-8-pin-din-connection/20-powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable.html
Kind regards, Steve.
Steve.
www.soundsheavenly.com
tuttivini
Posts 186
tuttivini replied on Sat, Aug 12 2017 11:37 PM
The Beoplay S8 Connection Hub is indeed a good option, but you need a INFRARED tv remote for it.
A lot of modern televisions (like my own Philips) use RF remotes nowadays. The S8 can't 'see' RF commands, so if you have such a remote, it won't work.
steve1977
Posts 911
steve1977 replied on Mon, Aug 21 2017 2:39 AM
Steve at Sounds Heavenly:
Hi diggs,
Steve.
Sounds Heavenly are proud to sponsor the BeoWorld forums!
I wasn't aware that it is as easy as one single cable to connect my non-b&o television with BL3. I have a sony tv with something that looks like a headphone socket. I can connect a headphone and can hear audio.
Besides the BL3, also possible to connect a BL2 or BL11?
Thanks!
Aussie Michael
Melbourne, AU
Posts 3,730
Steve1977 i think the trick is that once you can hear your headphones in the TV, if you adjust your volume on your remote does the headphone volume change?  If so, then it would be one cable :-)
Otherwise nothing can change the volume and they will be at one high volume
diggs2701
Miami
Posts 29
diggs2701 replied on Mon, Aug 21 2017 3:37 AM
Unfortunately there is no headphone jack so I have to go with the optical way. Thank you all for your help.
steve1977
Posts 911
steve1977 replied on Mon, Aug 21 2017 3:59 AM
Aussie Michael:
I think this works. i used to have an A9 connected to it (using line-in) and could change volume with my tv remote. I somehow thought connecting to ML was more difficult than just a cable.
what about the BL2? can use cables to connect BL3/BL2 combo?
Posts 2,165
Hi Steve 1977,
Yes, you can add a Beolab 2 and Beolab 3s (although these don't have their own volume control like the A9, so they rely on the TV headphone socket to be volume controlled).
Your Beolab 2 subwoofer needs a powered cable to generate the trigger signals that would normally be sent from a B&O television:-
http://soundsheavenly.com/line-in-connection/102--trigger-trs-.html
The Beolab 3 speakers will then plug into the two output sockets on the Beolab 2 using standard Powerlink mk.3 cables (one cable is needed for each speaker):-
Hi diggs2701,
If your TV only has an optical output then please see my post above which explains how to use a Beoplay S8 Connection Hub to connect to this socket and give control of the speaker volume.
Steve.
steve1977
Posts 911
steve1977 replied on Mon, Aug 21 2017 2:55 PM
great, thanks a lot. what about if i go with a bl11 instead of the bl2 (yet again in combo with bl3)?
Posts 2,165
Hi Steve 1977,
Yes, you can add a Beolab 11 and Beolab 3s, please use this cable from the TV headphone socket to the Beolab 11 (please note that this is a specially wired cable, not a standard DIN to RCA cable):-
http://soundsheavenly.com/beolab/129-minijack-ipod-pc-etc-to-beolab-11-subwoofer.html
The Beolab 3 speakers will then plug into the two output sockets on the Beolab 11 using standard Powerlink mk.3 cables (one cable is needed for each speaker):-
Please set the Beolab 11 to "Line" mode and set the Beolab 3s to "L" or "R" as required.
Steve.
steve1977
Posts 911
steve1977 replied on Tue, Aug 22 2017 3:15 AM
Got it, this is a bit confusing. So, the BL2 requires a powered cable, while the BL11 does not. Sorry for asking more questions, but like to make sure that I have understood everything and will buy the right cables.
I have not decided yet whether I will connect my BL2 or BL11 to my non-B&O TV (one stays with my BV7, the other one goes to non-B&O). Currently, my BV2 is connected to the BV7 (in surround setup). If I were to attach the BL11 to my BV7 instead, would I require a different cable or is it as easy as just switching it out. This would probably be my preference and then I would attach the BL2 to non-B&O with the cable above. However, I don't want to turn this into a nightmare and would keep the BL2 attached to the BV7 if this makes life easier. Advice appreciated.
Also, appreciate if you take a brief look at my other thread (http://archivedforum2.beoworld.org/forums/p/16772/212136.aspx#212136). I'd like to bundle my cable purchase to save shipping cost. Thanks!
Posts 2,165
Hi Steve1977,
Please don't worry, on the Beovision, you can use the same Powerlink mk.3 cable for either subwoofer, it is simply a case of swapping the sub and leaving the cable in place:-
Just checking your other thread in a moment!
Steve.
steve1977
Posts 911
steve1977 replied on Tue, Aug 22 2017 10:55 AM
Got it. So, BV to BL2/11 works with the same cable, while there is a different cable for headphone to BL2 vs. BL11? Let me switch them out over the weekend and then place my cable order with you. Thanks again for your help!
diggs2701
Miami
Posts 29
Sorry for the late reply but just go the cables/hub. Sounds Heavenly was absolutely fantastic. You were absolutely right, the S8 Hub had the speakers work perfectly with no sound adjustment from the TV remote. Any idea how to remedy this? Thanks, a lot of money invested... hahaha.
Posts 2,165
Hi diggs2701 Glad to hear that you are happy with the cables! For TVs with an infrared remote, the B&O website contains setup instructions that explain how to program the S8Hub to accept volume commands from the TV remote when using the TV optical output. If the TV doesn't have an infrared remote, then you need to use the headphone socket on the TV to connect to the Hub so that the TV can manage the volume sent to the Hub. Kind regards Steve.
Steve.
diggs2701
Miami
Posts 29
I was able to get the volume to work with the Comcast remote but not the LG. But it works! Thank you all for your help.
Page 1 of 1 (18 items) | RSS
DigiCert Secured Site Seal
