Can I DIY Masterlink and PowerLink Plugs?
Bouncer
Posts 20
Bouncer Posted: Sat, Aug 12 2017 1:27 PM
Hello all Beoer
I am going to relocate my BV7-32 and BV-10 and speakers to a new appartment.  I intend to use the old cables but the plugs have to be removed before I could pull the cables out.
I think I can open up the plugs for the speaker and re-solder them but the master link plug seems a bit tricky.  I am wondering if it is possible to buy the new master link plugs and reconnect myself. Does it require a special clam to close the plug and where can I find the pin assignment for the master link and power link?
Thank you all in advance.  Any suggestions on how to move them around is also welcome.
Bouncer
Aleksei
Russia
Posts 84
Aleksei replied on Thu, Aug 24 2017 1:53 PM
You can find the pinout here: https://www.beoworld.org/beotech/index.htm
The spare ML plugs are often on eBay.
https://beointegration.wordpress.com/
1:BV7+BL7.1+BS4+BL6000+BV6+BL2000+MLGW+Beo4
2:BV7+BL7.4+BL3500+BM5+BL3+Lutron GE/Sivoia QS+HikVision+Dune+LinTronic+BLGW+Beo4+Beo5+Essence remote+BeoTime+BeoLinkPC+BL4+KNX+... BeoMaster900
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Aug 24 2017 2:47 PM
Or you could leave some cable attached to each plug and reconnect using some of these: http://www.ebay.co.uk/itm/bang-olufsen-Master-Link-Junction-Box-Large-/222617110266?hash=item33d50386fa:g:MAgAAOSwAQtZlvZ9
Page 1 of 1 (3 items) | RSS
