How to change option setting
Griebel
Posts 416
Griebel Posted: Tue, Aug 22 2017 4:00 PM
I don't recall how to change the option setting. I have a BV 7-32 in a linked room and would like to set the correct option. It is currently in option 1 (had to perform a reset to default).
I remember how to display the option menu on the beo remote, but when I select L.OPT and then press 6, nothing changed, the tv stays in option 1.
What did I miss? Thanks.
Guy
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Aug 22 2017 4:03 PM
Make sure that the TV is in stand-by when you carry out the Option setting process.
Griebel
Posts 416
Griebel replied on Tue, Aug 22 2017 4:25 PM
Yes the tv is in standby mode but the option does not change.
stefan
200 miles from Struer
Posts 2,920
stefan replied on Tue, Aug 22 2017 8:52 PM
If you want to change option setting on a BV you must useV.OPT - video option, for Beolink products like BL active,passive .. And speakers like BL5, choose L?OPT - link option. For audiosystems choose A?OPT.
Stefan
Griebel
Posts 416
Griebel replied on Wed, Aug 23 2017 9:58 AM
Thanks. V.OPT worked. For some reason I tried L.OPT.
Page 1 of 1 (5 items) | RSS
