Beolab 3 wireless
ansink
Posts 3
ansink Posted: Mon, Sep 4 2017 8:14 PM
Is it possible to make the Beolab 3 wireless? So both the left and the right speaker only have a wire to the power outlet on the wall?
I want to get the Beolab 3, but I don't have the possibility to wire them from the left to the right of the room.
Duels
England
Posts 2,553
Duels replied on Mon, Sep 4 2017 8:55 PM
You can do this with a beolab transmitter 1 and two receivers (one for each BL3). But you will still have a (presumably short) wire from each speaker to a receiver and also the receivers need power.
elephant
AU
Posts 8,219
elephant replied on Mon, Sep 4 2017 10:09 PM
Yes you can daisy chain the Beolab 3s
Source -------- left ---- right
But you can cable both directly
left ------ Source ------ right
You can always cable tie (or use a cable sock) to contain the source cable and power cable together to a wall socket and then run the source cable inside the wall.
In the FLASH your B&O thread you will see many examples of this.
Also examples of discrete cable ducts that blend in to the wall.
You can buy a Receiver 1 if your Source is WISA capable. Or also buy a Transmitter 1 to make your Source WISA like.
But you will still have to run a second power cable to the Receiver 1 and then still have a source cable to the speakers.
There is no variant of the BeoLab3s that has WISA built in.
The smallest WISA speakers are the BeoLab 17s (I believe).
BeoNut since '75
Page 1 of 1 (3 items) | RSS
