Question for anyone that owns the Beoremote one with Bluetooth.
In the non BT remote it was easy to remove things you did not want in the LIST list.
But on my new remote one I can't seem to get rid of the options I don't want. Is there some secret command (like there was with the old Beo4) that I can't find documented?
Is there a place I can download a proper user manual for the remote that explains how this can be done.
Thank you for any help
The full User Guide is available here: https://www.bang-olufsen.com/en/product-support/accessories/beoremote-one-bt
