Remote control in link room-Split IR transmitter cable?
This post has 9 Replies | 1 Follower
Beolab1
Rotterdam
Posts 22
Beolab1 Posted: Fri, Sep 8 2017 11:33 AM
Hello all,
I have a Beovision 10 and recently bought a Beovision 6-22 from LifeStyle AV. A great little tv for in the bedroom! I connected it to the Beovision 10 by masterlink and RF cable. I even managed to get video from my Philips BluRay player on it, by using a HDMI splitter with one output connected to a HDMI to scart video downscaler, which is connected to a seperate scart input on the Beovision 10.
Ofcourse I can not use the Beo4 remote to control the Philips BluRay player in the living room, from the bedroom. But I have been thinking. What if I would have one IR transmitter cable with two plugs? The IR transmitter placed on the BluRay player and the two plugs connected to the PUC inputs of both the HDMI & Scart inputs on the Beovision 10.
Would this work over the masterlink cable from the Beovision 6-22 to the Beovision 10?
Thank you very much in advance for your thoughts!
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Sep 8 2017 2:02 PM
Hi and welcome to Beoworld!
Why not just add a second IR cable?  You should be able to mount the tow IR transmitters 'stood-off' from the Bluray's sensor but side by side.  The IR signal should be strong enough.
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Sep 8 2017 2:05 PM
Why not try adding a second IR cable.  Mount both IR transmitters 'stood-off' slightly from the IR sensor of the Bluray player - the IR signal should be strong enough.
Beolab1
Rotterdam
Posts 22
Beolab1 replied on Sat, Sep 9 2017 12:14 AM
The problem is that I live in a rented apartment. When I moved in, I discovered to my joy, that there was a masterlink cable and RF cable hidden under the living room floor onwards to the kitchen, both bathrooms and into the bedroom. So after a lot of soldering, I have installed Beolab 2000's in the kitchen and both bathrooms.  Also the Beovision 6-22 in the bedroom. Regretfully I can't put in a second IR cable. So therefore I came up with the split IR cable idea.
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Sep 9 2017 10:50 AM
But the extra IR cable only needs to run from the BV10 to the Bluray - so that it can control the BR when it's SCART input is selected.  This input would then be 'broadcast' over ML to the BV22.
Or am I totally confused by your setup ...?
Beolab1
Rotterdam
Posts 22
Beolab1 replied on Sat, Sep 9 2017 1:58 PM
Thank you very much! I did not think of that properly. I did not realise that the IR signal would go over the masterlink cable from the the BV6-22 In the bedroom to the BV10 and BluRay player in the living room. I will order one and try it out.
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Sep 9 2017 2:16 PM
No problem.  You could of course test the concept with the current IR cable by moving it across to the relevant SCART input.
Beolab1
Rotterdam
Posts 22
Beolab1 replied on Sat, Sep 9 2017 2:17 PM
Just switched a IR transmitter cable to the PUC assigned to the scart input. It's working! Thank you very much for your help.
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Sep 9 2017 2:20 PM
Great - always good to get feedback.  I am sure you will be back with more queries as you add to your collection - it's addictive! Smile
Beolab1
Rotterdam
Posts 22
Beolab1 replied on Sun, Sep 10 2017 7:42 PM
The great thing about your advice is that I went further and connected the BluRay to both HDMI port B & Scart input 2. I also connected the British Telecom Youview Box in the same way to input  A & 1. They both work perfectly now on the BV6-22 in the bedroom. I can even control Netflix. It's just perfect and I don't need any extra IR transmitter cables.
Page 1 of 1 (10 items) | RSS
