V1-32 and IR control issue
This post has 13 Replies | 1 Follower
Griebel
Posts 416
Griebel Posted: Mon, Sep 11 2017 11:14 AM
The IR control of my V1-32 progressively stopped working. First, I couldn't turn on the TV with any remote (Beo4/6). Had to use the BeoLink App instead to control the TV. However, after a few minutes, the IR control was again possible.
This went on for a few weeks, but now the IR control is no longer possible, even after a few minutes on. I can only use the Beoremote or the BeoLink Apps. Of course, I have tried the remotes on another V1; it just works fine. I also did several mains reset, but didn't help.
Has anyone had this issue? Can the IR control be dead while all the rest just works fine?
Thanks.
Guy
Fansastic
The Hague, The Netherlands
Posts 768
Fansastic replied on Mon, Sep 11 2017 4:54 PM
I had this issue with my V1-40, not able to use the remote anymore, only the app. Dead IR receiver in TV, they fixed it under warranty and on the invoice it was mentioned they had to change the motherboard.
I'm afraid you have to bring the TV to your dealer and hope the repair will not be that expensive.
Griebel
Posts 416
Griebel replied on Mon, Sep 11 2017 5:16 PM
The motherboard! Well, this will certainly be expensive[:\'(]
adriano555
Posts 9
Yes...the same happened to my V1 32 last week...
Really disapointed
The Beonic Man
Bristol
Posts 812
Glad to read this (sorry for you guys but helpful for me) as I was about to pull the trigger on a secondhand V1-40. I might reconsider!
B&O products are V1-32, BS2, H95, E8 and an Essence remote.
11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
mrCTE
Posts 70
mrCTE replied on Mon, Sep 11 2017 10:46 PM
Likewise BAND'OH!
Have we dodged a bullet here?!
Griebel
Posts 416
Griebel replied on Tue, Sep 12 2017 6:00 AM
Did some investigation and found that the problem could be solved by replacing the module IR Receiver & Room Awareness (PCB58). It's a small module which is located on the top on the TV.
adriano555
Posts 9
Really?
It's easy to do but where can you buy this PCB?
adriano555
Posts 9
This one?
Griebel
Posts 416
Griebel replied on Tue, Sep 12 2017 8:42 PM
Your dealer will be able to provide you with the module.
Griebel
Posts 416
Griebel replied on Tue, Sep 12 2017 8:43 PM
I will tell you once I have it.
adriano555
Posts 9
adriano555 replied on Tue, Oct 24 2017 10:40 AM
Hello,
did you receive the pcb? Is it repaired?
Griebel
Posts 416
Griebel replied on Tue, Oct 24 2017 6:20 PM
Not yet, although it arrived for some time at the B&O store, but they need to go to the post-office to ship it to me. That's seems to be a BIG problem Crying...
Griebel
Posts 416
Griebel replied on Tue, Oct 31 2017 1:41 PM
Received the module yesterday (it's indeed the one in the picture), replaced it in the TV... but alas it still does not work. I can't control via the remotes my V1-32.
Contacted the dealer again who now says that I need to replace the entire motherboard (PCB01 Video Engine).
I prefer not to think about the cost of this repair. On top of that B&O does not take back the IR module I purchased and which was recommended by support after the early (wrong) diagnosis...Angry
I love the way B&O is handling their (still remaining) customer!
Page 1 of 1 (14 items) | RSS
