hI
PLEASE HELP ME TO SOLVE MY PROBLEM.I PLUG IN MY DVD SYSTEMS(NOT B&O) INTO AV1 AND IT WORKS WITH VTAPE SWITCH.I ALSO PLUG MY HUMAX DIGI+C DECODER INTO AV2 BUT CAN NOT GET ANY SIGNALS.AFTER CHANGING THE AV SOCKETS THE DECODER WORKS IN AV1 BUT MY DVD SYSTEM DOES NOT IN AV2.
WHAT CAN BE THE PROBLEM____???
Thanks in advance
Robert
Have you been into the menus and set each input to the correct settings? The user manual on this site has all the details of what you need to do.
Stoobie
Yes I tried AV 1: Tape-1 AV 2 :Tape-2 or Aux
