Hi all!
I have a question: which non B&O plasma and which projector do you recommend for beosystem 3? ( Pana, Samsung, Sony?)
Ideally what you have and know that works great or you have seen and it is working well.
Thank you!
Liviu
Nothing?
only Beovisions? :)
Hi there
I have a optima hd65 running with my bs3 and it has bee running for years and is excellent.
I have a lntronic box sending some signals out when the cinema mode is selected but yeah excellent.
Nex time I will go for optoma again but a 1080p
Eclipse 65V1-32Beosound M5Essence MK2BLI
Thanks Seanie! I saw some good reviews for optoma HD 33 1080p projector. I'll give it a try and I'll post the results.
Non B&O plasma? I would recommend a Panasonic - and their new models actually have a quite nice design (they were quite clumsy and had a cheap 'plastic' look a few years ago). And as far as I know Panasonic delivers the panels for B&O's plasma tv's.
Thanks! I was thinking about Pana as well.
Anybody compared plasma and LED? Or B&O owners can tell us differences between 7(-55) and a 4(-65)?
I am interested mostly for movies.
Also, the commercial plasma can be an option since I have a beosystem 3 and I use digital tv, so no need for speakers and tv tunner.
Paul, which model of commercial plasma and how much it costs?
Beo4 'til I die!
