Anyone connect Beosound to Beolab7?
Superpaul
Posts 13
Superpaul Posted: Mon, Sep 17 2012 5:33 AM
I saw Beolab 7-1 in secondhand shop, anyone try to connect it to Beosound 3200 (or others)?
Do you think the sound is better than my Beolab 4000?
Thanks.
Nick
Nottingham
Posts 785
Nick replied on Mon, Sep 17 2012 7:11 AM
I would stick with the beolab 4000's because you can set them further apart which gives the stereo a wider effect, the 7.1 has a good sound and if its cheap enough I would get that and link it somewhere else in the house.
BeoHut
Posts 482
BeoHut replied on Mon, Sep 17 2012 7:37 AM
Just for a compact setup this should work. Don't forget to add a wall/table stand, otherwise the subwoofers (on the downside) will not work properly. They need some space for maximum results.
As Nick mentioned, the stereo image is rather small. I would use seperate speakers for a better soundstage and image.
Superpaul
Posts 13
Superpaul replied on Fri, Sep 21 2012 7:25 AM
Thanks for reply, when I return to the secondhand shop, the Beolab 7 has been sold......ha
Page 1 of 1 (4 items) | RSS
