Beomaster 3000-2: Mains hum on right channel only.
jamesymurray
Posts 5
jamesymurray Posted: Mon, Sep 17 2012 9:26 PM
Hello All, I'm a newbie here. I've currently got a Beomaster 3000-2 amp (with a set of Beovox 3800's and a Beogram 2202) I've had the amp for a while now, but in recent years has been unused and stored away. As long as I have had it, there has always been 50hz hum on the right channel only. It's present on both loudspeaker outputs, and the volume of the hum doesn't change with the volume of the amplifier (it's stays constantly at a low level). It's present regardless of the input selected, so it seems it could be introduced much further along the signal path. I'm planning to get the lid off over the next few weeks, but was wondering if any of you knowledgable folk out there might have and ideas/hints as to where I should be looking. Possibly a failed electrolytic? All the best, James
DMacri
United States
Posts 881
DMacri replied on Tue, Sep 18 2012 2:07 PM
If it's always the same level, it's not the amplifier power supply or the main filter caps. So this is being introduced after the amplifier circuits. I assume the hum goes away when the power is shut off, so it's not being injected on the speaker wires due to inductive coupling. I know, not very helpful, but sometimes it's good to eliminate what you can and see what remains, no matter how unlikely...
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Sep 18 2012 3:21 PM
First thing would be to replace the rectifier in the corner of the tuner board.
jamesymurray
Posts 5
Thanks for all the suggestions.
Well after a long time I finally had a chance to open the lid. Luckily the original schematic was still contained within the envelope which made tracing the fault a lot easier. Narrowed it down to a popped 47u cap just past the 'lo filter' switch. Replaced that which has cured my hum.
Bob
Charente, France
Posts 418
Bob replied on Wed, Oct 10 2012 1:38 AM
Noticed after reply you've cured the problem ...
b
P.S. I've restored one and sold just few weeks ago - therefore would suggest you pay attention to circuit area of switches and  speakers, Low&High in particular. Also remember there was other thread regarding to incorrect plug wiring (reversed neutral) - but it'll be to late for that - well done
jamesymurray:
Don't worry - be Happy
Page 1 of 1 (5 items) | RSS
